Cant get white sky card to be read in 800hd
  • av2008
    • 156
    Hello everyone, I hope someone can help me this is driving me crazy.
    I followed a tutorial of using NewCs to get the white card working in the internal slot. Im using a clone DM800.
    Im using Nabilo b/h IG2 with 72 bootloader. This may be causing the problem because im using older drivers.
    First I tested my old sky card and it reads perfectly directly with cccam.
    I then installed newcs 1.67 with cccam 2.1.2 and used the config below with my boxkey.
    <newCSconfig>
    <readers name="Card Readers">
    <device>
    <name>lower</name>
    <type>Sci</type>
    <node>/dev/sci0</node>
    <export>yes</export>
    <enabled>yes</enabled>
    <blocksa>yes</blocksa>
    <blockua>yes</blockua>
    <blockga>yes</blockga>
    <boxkey>xxxxxxxx</boxkey>
    <PTShandshake>no</PTShandshake>
    <crypto-special>no</crypto-special>
    <carddetect>yes</carddetect>
    <newcamd_port>10001</newcamd_port>
    <priority>round</priority>
    </device>
    <device>
    <name>upper</name>
    <type>Sci</type>
    <node>/dev/sci1</node>
    <blockua>no</blockua>
    <boxkey>****</boxkey>
    <newcamd_port>10000</newcamd_port>
    </device>
    </readers>
    <radegastserver>
    <enabled>no</enabled>
    </radegastserver>
    <cache>
    <emm>10</emm>
    <ecm>10</ecm>
    </cache>
    <newcamdserver>
    <name>cardserver</name>
    <deskey>01 02 03 04 05 06 07 08 09 10 11 12 13 14</deskey>
    <userfile>/tmp/users.txt</userfile>
    <user>
    <spider>off</spider>
    <rate>1</rate>
    <sidoverride>off</sidoverride>
    <status>access</status>
    <name>newcs</name>
    <password>newcs</password>
    <au>on</au>
    <allow>lower</allow>
    <allow>upper</allow>
    </user>
    </newcamdserver>
    </newCSconfig>
    Everything appears to work. I can see the card in cccam and newcs info and my entitlements are showing correctly.
    The thing is all I get is a black screen and nothing else until I slip my old card back in. My white card works in the sky box so its not the card.
    Any ideas?
  • cactikid
    • 12017
    no idea but i heard the white card has a lower voltage so putting it in other box may burn it out.
    • av2008
      • 156
      Yeh, I thought that too but that was a common problem with the new italian sky cards. The uk ones seem to handle the voltage better. This is what someone told me. I was skeptical but its been in my dm800 a while and it still works in the sky box so it cant be burned out.
      • icaicm
        • 100
        <newCSconfig>
        <device>
        <name>lower</name>
        <type>Sci</type>
        </device>
        <device>
        <name>upper</name>
        <type>Sci</type>
        </device>
        </readers>
        <radegastserver>
        </radegastserver>
        <cache>
        <emm>10</emm>
        <ecm>10</ecm>
        </cache>
        <newcamdserver>
        <user>
        <rate>1</rate>
        <name>newcs</name>
        <au>on</au>
        </user>
        </newcamdserver>
        </newCSconfig>
        Any ideas?
        hello
        try this
        <device>
        <name>lowe</name>
        <type>sci</type>
        <mhz>368</mhz>
        <parity>odd</parity>
        <reset>normal</reset>
        <export>Yes</export>
        <enabled>Yes</enabled>
        <blocksa>No</blocksa>
        <blockua>No</blockua>
        <blockga>Yes</blockga>
        <blockC0>No</blockC0>
        <boxkey>*******</boxkey>
        <autosid>Yes</autosid>
        </device>
        this should work 100 %
        just modify the freq according to your need
        • av2008
          • 156
          Originally posted by icaicm
          hello
          try this
          <device>
          <name>lowe</name>
          <type>sci</type>
          <mhz>368</mhz>
          </device>
          Cheers for that ill try it later. The thing is on a different forum someone posted that the sky card must do a callback in the sky box to be paired properly. My sky box isnt connected to a phone line so that could be an issue?
          Once I try your config ill let you know what happens, thanks again.
          • 2tone
            • 483
            not heard about the call back yet but as long as your white card has been turned on the right way it should work with out a prob well untill they do the full change over then we will see what this card will do
            • cactikid
              • 12017
              something happened in uk and irl on different channels=no signal and came back after a few mins.????
              • av2008
                • 156
                Yeh i got that signal problem for three hours last night.
                I sorted it now using cccam 2.05 and Newcs 1.66 , thanks for everyones help
                • cactikid
                  • 12017
                  should have said it was on a sky hd box wonder if it was getting an upgrade.
                  • av2008
                    • 156
                    I checked on my hd box and old panasonic box, both were down with some channels last night so it cant be an upgrade.
                    • av2008
                      • 156
                      This thing is driving me mad, I now have a new problem. Hd Channels on a certain TP that Discovery hd and scifi hd are on seem to freeze every three seconds or so. Its not a card issue, its a tuner issue Other HD channels like History work fine. I tested on my sky dish that works perfectly with the sky hd box and I tested on another dish. There is no ber but a fluctuating signal as the breakup happens, I tried a rescan and downloaded new settings has anyone got any suggestions.
