patched modern images for dm800 clone
  • mfaraj57
    • 557
    Load these images to internal flash
    features
    1-fix remote control poor performance
    2-fix card readers problems
    3-fix tuner problem
    Warning:
    we have three generations of dm800 clones
    You should know which one you have before upload any image
    first:secondstage bootloader 69
    shortcuts BL69 or ss69
    second: secondstage bootloader 70
    اshortcuts BL70 او ss70
    third secondstage bootloader 72,72
    shortcuts BL72 او ss72
    to know you dreambox BL version
    1- At start of reboot there is number appears for short time at small screen,this is BL version
    2- Put dreambox at setup or stop mode
    unplug electical cord
    plug it again while pressing the power button at front tell dreambox ip appears
    then from pc
    start-run-telnet ip dream
    Note; do not care what about written in arabic in pictures,it is not important
    if you do not know what your BL version then use images for BL69
    "Load these image at your awn risk,i have tested only nabilo bh .11 for BL69 and it is working properly
    for BL69:
    NabiloBlackHole 011G2 DM 800 BL69
    Gemini 4.4 for dm800 modified
    for BL70
    NabiloBlackHole 011G2 DM 800 modified for clones with BL70
    The Gemini2 Project 4.30 DM 800 modified
    pli-enigma2 jade3 dm800-20090719_BL70 m
    newnigma2-v2.6 DM 800 modified for clones with BL70
    for BL 72:
    Gemini 4.30 for DM 800 HD patched with loader ver. 72 Factory SET
    OoZooN-CVS-full-dm800-20090625 patched
    LT-Fifth.8-dm800-b for DM-800 patched
    EDG-Nemesis-1.0-RC3-dm800-e2_22-07-2009 patched
  • sarsippius
    • Sep 2009
    • 5
    I just tried the Gemini patch. The good news is the remote is working fine now.
    However I am still getting a tuner failed message. Plus I am using a single satellite connection but it only gives me the choice of 2 satellites; Hispasat 30.0 W and Astra 19.2E?
    Anyone else had any similar problems?
    • mfaraj57
      • 557
      Hi
      seems all patched images have limited sat choices
      i overcome the problem by loading channels list by dreamset containing four sats
      • tim rob
        • Mar 2009
        • 5
        Sorry for the noob question mines a clone and says Dreambox Second Stage Loader BUILD #62, built 20080911 and on bott up says #66 can you advise please
        Regards
        Tim
        • mfaraj57
          • 557
          Regards
          Tim
          Hi
          you dreambox carru bootloader 66 which is old
          load to your dreambox patched image with bootloader 69 and i prefer nabilo blackhole .11 with bl69
