DM800 - can't install multiboot with FlashWizard
  • frof
    • Sep 2009
    Hi,
    I just brought a DM800 this week. I have added a 60GB hard drive and installed the latest firmware from Dream-Multimdeia (09.09.2009).
    I have setup the box and it's working great and now I would like to try other images and it seems like Gemni is a good one.
    I have downloaded FlashWizard Pro and it can format a USB stick and mount it but when I switch to the next tab it tells me the boot menu is not installed, so I install it but then it can't see the USB stick or the hard drive.
    I could try to install Gemni on the internal flash but would obviously prefer to have a known goof config to fall back on!
    Any ideas?
    Cheers.
  • jims45
    • Sep 2009
    • 4
    Same problem
    I have exactly the same problem and have tried diferent usb sticks...advice would be much appreciated.
    • bauhaus
      • 15
      As far as I know you can't use FlashWizard on the DM800.
      • dallyis
        Barryallen is used to multiboot on this receiver it is available as a plugin.
        • chrl2000
          • Sep 2009
          install oozoon lin pkage if barryallen not installed go plugins and dowload barr... then do what ever you want
          it is the best way for DM800 multiboot 60.GB is not enough if you wish to record HD format..
