dm 8000 reboots
  • mm009b
    • 221
    dm 8000 reboots
    Hi folks sorry if this is posted before if so i cannot find it
    anyway i have dm 8000 with a 1.5 terabite hdd and a built in hp slimline dvd r/w
    problem is i can record movies onto hdd
    when i use dvd burn the box just reboots i have tried most images but get same results on all images
    any help much appreciated thanks in advance
    cheers all
  • firestorm
    • 1550
    have you tryed to using the latest drivers
    • mm009b
      • 221
      no mate i never even gave that a thought the box is only 3 weeks old should they not be upto date it was fitted proffesionaly how do i update drivers do you mean for dvd r/w and thanks for your swift reply mate much appreciated also it plays dvd's ok it just won't write i have also tried creat dvd iso and box does the same ie reboots
      • westkill
        • 2378
        is it not in menu>setup>software managment>software update
        i think
        with nabilosat image
        • westkill
          • 2378
          or hold the blue button for gemini
          i think as well
          • mm009b
            • 221
            no guys box is upto date im on newnigma 2
            17/09/2009
            i think what firestorm was talking about dvd r/w driver's
            how do i check that stuff out
            and how do i find info in box ie var/etc or what
            ave also sent crash reports to dreambox but no reply
            • firestorm
              • 1550
              dreambox are always very slow at getting back to you
              if you are using nabilosat
              then you need to fpt them over to temp
              green bottom ,yellow and choose manual install ipk packges
              you could also try this plugin to see if that works
