Dreambox 800 with 8 LNB's .. Help Please !!
  • Moonor
    • Sep 2009
    Guys, I need help with this installation :
    Dreambox 800 HD
    Spaun SUR 211 F Uncommitted switch with LNB1 and LNB2 inputs ( Each input has 1 Diseqc connected with 4 LNB's. i.e 8 LNB's in total are connected to the Switch thru 2 Diseqc's)
    Does anybody know how to do the correct installation in the Dreambox Menu .. ?? Also the switch has a button with 3 options, uncommitted, tonebourst or something else .. what is the correct position .. ?
    I have tried many attempts to play in the advanced settings page for the satellite installation but not all satellites came thru although I tested it before on an old Dreambox Gemini and all worked ... Even the ones that came thru take a lot of time and need to stay on a channel for a while to start seeing the picture ..
    Thank you so much ...
    Moonor
  • tulipman
    • Nov 2010
    Hi there, Moonor.
    I found your request in this forum, but it's already 'dated'.
    Wonder if you ever got your Dreambox working with 8 LNB's.
    I'm also 'in the process', but no time to finish it off!!!
    Check out my setup here:
    backside-view:
    My Ham shack (my callsign: PA3BKL) - tulipman's Photos
    Frontview:
    Found also some other info here:
    Up to 8 lnb's on your dreambox - in pictures
    (that thread is closed unfortunately)
    Let me know if how you are going with your eight LNB dreamproject.
    Really want to be in touch with you.
    Cheers
    Robbert
    Soesterberg, Netherlands
    Dreambox 800 HD
    Moonor
    • dave-h
      • Apr 2010
      • 659
      Originally posted by tulipman
      Hi there, Moonor.
      backside-view:
      Frontview:
      Cheers
      Robbert
      Nice set-up
      • dctyper
        • 2539
        how many channels do you actually watch
        • tulipman
          • Nov 2010
          I alway go for the max!!
