Star H2S HDFreaks 5.3 build-59
  • fudge1
    • Jul 2014
    • 22
    Zgemma
    only flash if you have a NEW Zgemma H.2S
    Build info:
    language english
    AV 720p
    INSTALLED ON THIS BUILD
    Plugins:
    Cacheflush
    EMC git20151003 (setup) DO NOT DELETE THIS BOX WILL NOT BOOT
    Media scanner
    OpenWebif
    Plugin Updater
    SoftWare Management
    Swap Manager
    XMLTV-Importer
    Skin:
    Slyk 1 HD v1.58
    ZGEMMA S2 SETTUP
    ADDING A BIGGER USB DRIVE TO THE BOX FOR RECORDING
    1st to initialise your drive or AFTER FLASH (make sure zgemma folder is not on usb)
    Insert usb in back
    Turn on
    Menu
    Setup
    devices
    harddisk
    Initialisation (select ur usb/
    hdd
    Initialise with red button
    Now Check
    Menu
    Setup
    devices
    harddisk
    filesystem check
    then
    Menu
    Setup
    devices
    harddisk
    convert ext3 filesystem to ext4
    512MB SWAPFILE SETUP
    Menu
    plugins
    Swap manager
    Make sure its created, enable at startup and active- or see setup thread.
    everything else should be set to correct paths after reboot.
    SCANNING CHANNELS
    Menu
    setup
    service searching
    autobouquets maker
    providers. Change sky uk: to your area.
    save
    delete bouquets
    start scan
    reboot
    PICONS
    add the picon folder to your HDD
    SCREENS
    build update
    HDF Build 59
    slyk 1 HD V2.0
    hi guys i take no credit for this backup as it is not mine
    RAR password: qwerty
