Dm800 clone DCC problem
  • can57
    I have a Dreambox 800HDclone - I've put a Pli image on it and CCam 2.1.1.
    It powers up fine and I can use the remote to navigate through the menu's.
    It seems to be set to DHCP - when I power it on and hold the power button it, an IP address of 192.168.1.8 appears.
    If I do a ping -t to this address, it pings continually and it is visible in the list of clients from the router.
    Dcc v2.95 can find it in the search at this point.
    I cannot connect via Dcc v2.95 no matter what option I try - I've tried router, with check etc but it continually returns the error:
    'Dreambox login failed'
    user: root
    password: dreambox
    If I powercycle the box, I can't ping, see it in the router, or connect.
    Can anyone suggest how to proceed - be it a different image or whatever..
    Thanks.
  • westkill
    • 2378
    have you tryed setting a static ip on the box instead of dhcp
    then reboot
    using the same string as your pc,s ip and changing the last number
    • westkill
      • 2378
      try this dcc for E2
      Digital Kaos - Downloads - DCC E2 v1.20
