DM800 Replacement Tuner
  • dazmaul
    • Mar 2009
    • 61
    Hello all, I am back again with Tuner problems - shock!
    Does anyone know where I can buy a new ALPS BSBE2 (DVB-S2) Tuner?
    My DM800 has started playing up again. When I select any of the Sky HD channels the signal rate goes to 0% and the box stops working. If I select a normal channel and then restart the box it comes back on OK working with "normal" channels.
    I have tried rescanning the satellite but as soon as it attempts to scan a DVB-S2 transponder it dies again. It was working fine until recently.
    Has anyone had similar problems, knows a fix or anything?
  • westkill
    • 2378
    not 100% if you can change the tuner in a clone
    not unless you open it up and check the tuner first
    if it is replacable
    unless someone else can confirm this either way
    • cauliflower69
      • 261
      I have had issues with Disc HD only but never freezes the box. You can change the tuner in the 800 np. You can grab one on ebay.de is where I spotted one
      • dazmaul
        • Mar 2009
        • 61
        How do I know if it's replaceable?
        • cauliflower69
          • 261
          because its plug and play
          • dazmaul
            • Mar 2009
            • 61
            If that's the case could the above issues be explained by the tuner being loose/not being correctly inserted?
            • cauliflower69
              • 261
              not as far as i know
              • westkill
                • 2378
                this what a plug n play tuner looks like
                if you look at the top you will see the plugin bit
                or it would be soldered
                • patelk7
                  • Aug 2010
                  Does anybody know where the best, cheapest place is to get a dreambox 800 hd. I understand these do not come with dvb-s2 tuners as standard so where is the best, cheap place to get these also
                  Thanks.
                  • Nev1337
                    • Aug 2010
                    • 57
                    its like change pci card on pc verry easy
                    • .: JaCkPoT :.
                      Retired Sat TV Addict
                      • Aug 2008
                      • 5607
                      Thanks.
                      Uk = ukdreamshop
                      China = YaoXin Electronic CO.,LTD
                      Tony @ Yaoxin is cheaper as he is in China! Im sure all DM800 do come with a DVBs2 tuner otherwise it wouuldn't be HD?
                      ___________________
                      In the good old days, I had
                      DM800s HD
                      Openbox S10
                      TM500
                      DM500s
                      90cm FortecStar dish
                      Maxx 110cm Dish
                      Technomate 2300 Motors
                      • asuk
                        • Aug 2008
                        • 37
                        Originally posted by .: JaCkPoT :.
                        Uk = ukdreamshop
                        i bought my dm800 with a cable tuner. a few weeks ago i bought a sat tuner from china via fleebay about ?40. everything works spot on
                        • tab99_uk
                          • 227
                          my m8s got a dm800 with same tune failed fault its a rev j tuner and a rev j board which version of tuner will work will rev m work or rev l3??
                          • bubbles69
                            • Feb 2010
                            • 1150
                            For rev J you need L3 tuner
                            • tab99_uk
                              • 227
                              i emailed uk dreambox shop he said i will need the old type l3 tuer said he will have them in 2 weeks time
                              is thier anyone else that sell the L3 tuners
