DM800hd DEAD
  • hodgey99
    • 9
    DM800hd DEAD
    Ive got a clone DM800HD box from china when i turn it the ethernet light comes on but nothing else happens. tried plugging power back in and out quickly, cant get it to connect using dreamup either pc dosent see the box. Hope someone can help me as its doin my head in thanx.
  • DJSimo
    • 453
    First thing to do is go here and introduce yourself http://www.digital-kaos.co.uk/forums/f2/
    Then tell us a bit more about problem like has it done this from new, or has it been working and now it isnt ???
    • hodgey99
      • 9
      It wos workin with the nabilosat blackhole image but wos havin problems with tunining the sats in. so i changed the image to PLi� Jade2 Enigma2 updated 30.03.09 now it wont even boot up
      • DJSimo
        • 453
        Is there anything at all on the front panel??
        Also have you tried disconnecting the power lead from the power pack then plugging it back in as sometimes this works with mine when pulling lead out of back of box doesnt.
        • hodgey99
          • 9
          No theres nothing on the front at all. tried unplugging and plugging it back in loads of times still nothing. do u think it can b jtaged
          • DJSimo
            • 453
            How are you trying to connect to your box is it via dreamup and a Null Modem cable?
            • hodgey99
              • 9
              YES IAM TRYING WITH DREAM UP AND NULL MODEM CABLE
              • DJSimo
                • 453
                Ok all i can suggest is keep trying, start dreamup click connect and then keep connecting disconnecting power until it finds the box if this doesnt work then maybe someone else can come up with another solution for you.... good luck
                • shaks08
                  • 37
                  Hi, i recently purchased a new dreambox from china and i had the same problem as it just wont power up, i changed the power adaptor and it was on so worth a try
                  • satcat
                    • Aug 2009
                    • 14
                    try this: hold the power button in, THEN plug the power lead in the back, should lit up front panel with DHCP info,,u can then flash it through a web browser, cheers satcat
                    • DM800
                      • Aug 2009
                      • 21
                      try to use Dream UP flash older version IMG to box
                      thank you
                      • seffe
                        • Aug 2009
                        • 10
                        reply to dm800 dead
                        dont english people and australian people know that a db clone
                        will die for ewer with pli or gemini.buy a genuine and you will have a warinty for one year.
                        seffe from sweden
                        • modey
                          • 60
                          seffe from sweden
                          very helpful
                          • dctyper
                            • 2539
                            seffe from sweden
                            my clone has worked for 3 years without fault
                            Wavefield Ds 55cm at 13E 19E and 28E receiving everything out there on 2 dm800hd
                            previous life dm800hd and 500c on cable screw you nag3
                            • C64
                              • 2394
                              seffe from sweden
                              I don't know about the DM800, but my clone DM500-S uses Pli images no problem, I've used them for about 4 years, I am currently using Pli Jade 3.
