dm800 hd
  • john1509
    • 215
    dm800 hd
    ok guys i have just got myself a dm800. it is taking over from my faithful dm 500. got my 800 up and running on 28e. but for the life of me cant get it to move my motor. if i put my 500 back on the motor moves fine anyone got anything that i can try tx. someone said i have to clear the motor settings cos it has the settings init for the 500 is that right
  • john1509
    • 215
    hi guys cant any one help me out with something to try tx
    • kdol
      • Sep 2009
      • 45
      Hi, Also in same position as you. No problem with DM500 but 800 is a different story!!
      My findings are that on reboot using a sat finder meter power is shown and I can manually move the motor.
      My conclusions so far are that the motor is OK, the cabling is OK and its a tuner configuration or more likely a software problem.
      Mine's a clone and I am in touch with the supplier but no response as yet and dont anticipate one till next week.
      What I find strange is if I go into Sat Finder (even when the dish is pointed at a sat and has a strong signal) initially there is no signal shown. If I click the Tune Manual transponder option & change this to Predefined transponder there is still no signal. Then when I click on it again and switch back to manual transponder the signal is shown fine SNR & AGC - so why now and not when first going in?
      When I shin up the ladder I can move the motor using the button on it but not via the 800 itself ... weird!!!
      When I come out of Sat Finder the power in the LNB cable is switched off. ie the sat meter goes dead.
      When I go into Positioner - this is the time when that power is critical - there is none available hence none of the options/buttons do anything to move the motor.
      My conclusion at this point is there is sufficient power to move the motor etc but the 800 is not sending the signals to do so - via power to lnb.
      It is possible that my tuner settings are contributing to this problem but have tried so many alternative settings that I think it is unlikely.
      I don't like the way that after setting satellite etc on tuner this data is not passed to sat finder either.
      If you get anywhere with yours let me know and I will do likewise.
      Good Luck.
      • john1509
        • 215
        hi kdol will do m8 will have a go tommoz not holding my breath tho
        • westkill
          • 2378
          what settings you got in your tuner configeration
          • kdol
            • Sep 2009
            • 45
            I've tried a whole variety but last opinion was to use advanced and drive the motor to scan individual sats.My settings were
            Tuner - Advanced
            Sat - take your pick (Thor 3)
            LNB - LNB1
            LOF - Universal
            LOF/L - 09750
            LOF/H - 10600
            Threshold - 11700
            Volts - Polarization
            Inc volts - No
            Tone - Band
            Diseqc - 1.2
            Toneburst - None
            Committed - None
            Fast Disq - No
            Seq repeat - No
            Command - committed, toneburst
            Uncommitted - None
            Dis Rep - None
            Long - 1.300
            Lat - 55.040
            Usals - No
            Stored - sat position ie 1 for Thor 3
            Can you spot anything from these? Cheers. KD
            • westkill
              • 2378
              using advanced as youve quoted
              have you tryed having usuals as yes
              is your longitude and latitude set for your area
              longtitude***** west
              latitude ***** north
              • kdol
                • Sep 2009
                • 45
                The short answer is Yes & Yes.
                The longer response is that initially wanted to use the simplified option with Usals and it was following numerous failed attempts in that direction that I decided to use the technique that worked best with the 500.
                But as you can see none of this has worked.
                The 800 handles a single satellite fine as long as it has not got to find it!!
                • westkill
                  • 2378
                  have you tryed adding these settings in post #25
                  with dreambox edit v3.0
                  here
                  Digital Kaos - Downloads - Dreambox edit . V3.0
                  • kdol
                    • Sep 2009
                    • 45
                    I have been concentrating on trying to get the thing to work so have not really done anything else yet. Totally new to all of this and its a heck of a learning curve!!
                    However, appreciate your pointer and have loaded the file. Was something I was interested in but had done nothing about so far.
                    Thanks for your help.
                    One (other) aspect I am battling with is how to load cccam and newcs. I have looked through the 'blue button' and nothing jumps out at me and have then trawled through how else to load them. Bit undecided on this.
                    Equally, I have not flashed anything as yet is this something I should have done by now?
                    Cheers.
                    • westkill
                      • 2378
                      is your box a original or a clone ?
                      you probally need to flash a new image
                      if you havnt so far
                      • kdol
                        • Sep 2009
                        • 45
                        Its a clone. What I have made out so far is that its BootLoader72 with I believe Gemini 4.4.0 on it and of course Enigma2.
                        I have downloaded NabiloBlackHole_DM800_011.nfi but as yet have done nothing with it.
                        Any recommendations?
                        • westkill
                          • 2378
                          you could use this one
                          here
                          but is your box connected to the net/router ?
                          and its a gemini image
                          then you can download cams/emu,s and config files
                          i think
                          blue button>addons>
                          it think off the top of me head
                          • john1509
                            • 215
                            well been trying to get my motor to work today on my dm800 still no joy. but when i plug my dm 500 in it works fine. i have tryed the settings in this post but nothing. if i connect the dm800 to my sky dish it works ok. is there any other settings that someone has for me to try tx
                            • bobbyjoe
                              • 33
                              These My Settings
                              Configuration Mode Advanced
                              Satellite Astra/Eurobird (28.2E)
                              LNB LNB 1
                              Priority Auto
                              LOF Universal LNB
                              Voltage Mode Polarisation
                              Increased Voltage No
                              Tone Mode Band
                              Diseqc Mode 1.2
                              Toneburst None
                              Committed Diseqc Command None
                              Fast Diseqc No
                              Sequence Repeat Yes
                              Command Order Committed,Toneburst
                              Uncommitted Diseqc Command None
                              Diseqc Repeats None
                              Longitude
                              Latitde
                              Use Usuals No
                              Stored Position 001
                              Next Sat store position 002 and so on Ihave 7 setup
                              Hope this Helps bobby
