Blacky1973, long time no see, hope things are ok, anyway if you're still using my backup image with Autobouquetsmaker then do this;
1. Go to menu-plugins then press red to remove installed plugins find 'autobouquetmaker' and remove old version
2. Go to menu-plugins then press green to install plugins find autoboubouquetsmaker' and install latest version
3. Go to autoboubouquetsmaker in setting and select 'delete bouquets'
4. Go to autoboubouquetsmaker in setting and select 'start scan'
this will remove the none working BT HD channels
Question for you m8, you still got your custom addons for kodi direct, been few members asking how to get the most out of Kodi direct on a zgemma.
Hi mate, yer I think they are still in my Dropbox, I'll have a look and if they are I'll make a post with them,
Regarding the auto bouquets maker, I followed your guide above but when it comes to starting a scan I get a 'cannot read data' error message, rebooted my box now all channels missing.
Or just edit the Sky UK xml file and remove the BT HD channels from the whitelist.
If using an old image, you may not be able to load the newest ABM files from the plugin feed.
