Best image and skin for Zgemma 2s.
  • blacky1973
    • 304
    Hi I was using MTPockets openatv image on my Zgemma but yesterday it got stuck on 'boot' when starting up so needed to re-flash my box, MTPockets is no longer available to use so flashed with Sucmnsee's Vix image however I don't like the skin it has so tried to change it but again on start up it stuck on 'boot' so had to flash again.
    What would you say was the best image to use and where can I find it?
    Also what would you say was the best skin?
  • martin035
    • Apr 2014
    • 1308
    Try my old 2s backup image;
    As Many members know, I updated to a H series Zgemma a while back, but DK member 'madness85' has an original Zgemma S and has developed his image for use by others on the forum, this image will work on a Zgemma S or 2S Openatv5.3 Backup Image with New improved SkyQ Skin, OTA update safe * AutoBuoquetsMaker autoupdate daily
    Comes with kiddac's original sky skin, you will have to update the image once installed as its a bit dated now but still works.
    If you don't like it then try whoosh's build but you'll have to google it as linking to other like forums is against forum rules.
    • blacky1973
      • 304
      Cheers mate, I went with Whoosh's build, seems OK so far but don't like the skin so tried to change it to MTPockets BluedHD but again on startup it freezes on boot so had to re-flash.
      Guess I'll just have to stick with it.
      • martin035
        • Apr 2014
        • 1308
        Blacky1973, if you don't like the skin thats on whoosh's or my image then install another skin via the plugin skin downloads or .ipk file ie chab's excellent skyQ skin, as it sounds like the blueHD skin you've installed has a bit of bad coding in it which is causing the boot issues.
