zgemma star 2s
  • stevo1
    • Feb 2017
    zgemma star 2s
    hi can anyone help me please i just purchased a zgemma star 2s box and its stuck on boot tried loading a new image off a usb and it dont show usb just says boot any help would be apprieciated
  • DOUGALMCD
    • May 2011
    • 3229
    Did you insert usb and then connect power anyway martin035 does a backup and tells you how to do it have a read.
    This Backup Image is for the Newer H series of Zgemma Satellite receivers, it will work on the H.S and H.2s and confirmed working on the H.2H by Hadron @post #116 (requires additional setup for cable see post #119) but hasn't been tested on the H5 Openatv5.3 Backup Image with New improved Sky Skin, OTA update safe ?
    • smurph
      • Dec 2013
      • 31
      I had similar a few days ago, and after a web trawl....just press some buttons on remote, and it seems to bring it out of boot....whether this is intended or not I can't advise.
      • gersweeney
        • Jan 2014
        • 12
        Zgemma Star 2 S
        Hi
        The zgemma you need a Kingston 8gb usb or a similar well known usb to flash a zgemma they are very temperamental about the usb drive i use the Kingston turn off your box at the back insert the the usb in the back and hold the the power on the front you will see boot and then flash you then release the button the front
