hi can anyone help me please i just purchased a zgemma star 2s box and its stuck on boot tried loading a new image off a usb and it dont show usb just says boot any help would be apprieciated
zgemma star 2s
Did you insert usb and then connect power anyway martin035 does a backup and tells you how to do it have a read.
This Backup Image is for the Newer H series of Zgemma Satellite receivers, it will work on the H.S and H.2s and confirmed working on the H.2H by Hadron @post #116 (requires additional setup for cable see post #119) but hasn't been tested on the H5 Openatv5.3 Backup Image with New improved Sky Skin, OTA update safe ? -
Zgemma Star 2 S
The zgemma you need a Kingston 8gb usb or a similar well known usb to flash a zgemma they are very temperamental about the usb drive i use the Kingston turn off your box at the back insert the the usb in the back and hold the the power on the front you will see boot and then flash you then release the button the frontComment
