Best skin for Zgemma H2S
  • smurph
    • Dec 2013
    • 31
    Have just received a H2S, and it has Q skin v1.6 (have seen 1.7 here), and IMO a little awkward to get around...not very intuitive, no PIP!
    Is there better, e.g. Slyk?
    And if so, how can i update, to either?
  • martin035
    • Apr 2014
    • 1308
    Why not try the other skins, you can either install via the menu-plugins-down-Green Button-skins and install the skin you fancy then switch to that skin via menu-setup-usage&gui-skin setup.
    Or for skins not available in the github then these have to be install manually, have a look at Kiddac's webpage for the Slyk skin and others with instructions on how to install.
    https://slyk1hd.yolasite.com/
    PS. Don't think any skins have PIP
    • smurph
      • Dec 2013
      • 31
      Thanks, though sadly I have had to return my box as it didn't work thru TP links (homeplugs) [why i can't understand, but oh well].
      Yes, the Slyk skin looks better, was wanting someone to confirm such.
      Sorry, didn't mean PIP, but preview screen beside channel list (not sure what its called), though the Q skin on above box did have this, and online images show that Slyk does too.
      • martin035
        • Apr 2014
        • 1308
        Don't give up with the Enigma 2 satellite box, could have been faulty box or compatibility issue between the homeplugs and the Zgemma, perhaps have a look at an Edision OS mini this has built in WiFi which will connect to your router with ease.
        • fudge1
          • Jul 2014
          • 22
          flash my image below m8 as the sly skin init
          • smurph
            • Dec 2013
            • 31
            NO, am intending to get a replacement Zgemma, and will confirm with vendor pre purchase if it works with homeplugs. Still trying to find out the best skin to get/use?
            Sorry fudge1, don't see anything there?!
