DM800S BOOTING PROBLEM
  • king03j
    • 18
    Hi guys, hope you can help with this!
    I have installed the nabiloblackhole sat image and i have tested it but it does not boot. The normal Nabilosat screen appears, the box starts to boot, the screen goes blank and the box freezes on the Dream Multimedia Booting screen, the red LED goes off and on intermittently the loading/progress bar goes no more than a tenth of the way across the screen. I have tried re-flashing this particular box 3 times but it is still faulty. Please help.
    Thanks!
  • kevin64
    • 170
    have you tryed reflashing it with null modon cable and dreamup seems like this might be your only way or have yu tryed a diiance imaga like pli to see if that will boo
    t
    • king03j
      • 18
      Thanks for replying, i have tried dreamup and flashing by the browser but both have the same outcome. Where can i locate the diiance image please?
      • Superman
        • 520
        Have you tried with Dreamup Enforcer?
        • kevin64
          • 170
          sorry mate thats my bad spelling diffance image go to the downloads and see whats in there
          • Superman
            • 520
            Hi Mate,
            Try a older bootloader, try NiabloSat 0.12 bootloader SS70, this may work for you.
            • kevin64
              • 170
              if you box is a clone then you need to use a clone image it has boot load install on most clone images now here a link to the gemini clone image just put your mouse on the blue letters and press ok
              Digital Kaos - Downloads - Gemini2 v4.5
              • Superman
                • 520
                Use niabloSat clone patched image, its the best image out there, its better than gemini.
                • kevin64
                  • 170
                  nablio sever has been down for a while you cannot download your cams or pulginsand images are for the user to make there own mind up witch one they like try them alll
                  • Superman
                    • 520
                    yes true kevin64, but many users are not well knowledged about this so we have to try and guide them. Most images are very similar if were being honest, again its personal choice and it depends on what your doing with it.
                    • king03j
                      • 18
                      so far i've tried bootloader 70 & 72, gemini 440, 420 & NabiloBlackHole 011G2_DM800_ss70-modified and non of these have worked, they all do exactly the same, the initial screen comes up then it goes black and the boot screen freezes - i've just tried Nabilosat Enigma2 Black Hole - DM800 v0.12 FOR CLO (39.25 MB) and that does the same.
                      • kevin64
                        • 170
                        ok let just try and get this guy up and running while i say use gemini because just seeing if his box will bootand if it does then maybe he was not useing a clone image in the first place
                        • kevin64
                          • 170
                          well it does not look like you are getting anywere useing the interface you say you have tryed dreanup what happens in dreamup when you start to load image des it go allthe way and flash the box
                          • Superman
                            • 520
                            Hmm, have you tired just install the SS72(through dreambox), then a image, maybe your bootload is curropt? Also on dreamup make sure Network box is Unticked.
                            • king03j
                              • 18
                              thanks mate!
                              Yes in dreamup it goes all the way. Most of the images i have tried i have done via the browser though. The same result on every image is that the screen shot of the image shows on the TV whether it be nabilo or gemini then it goes black
