DM800 - ghetto fan mod = simple & silent
  • punter987
    • 22
    Stage 1
    Satge 2
    with hindsight I probably should have done less work and stuck with Stage 1 but the lid didn't want to go on easily! doh The fan was more 'sturdily attached' then too
    Summary (should take you less than an hour)
    remove lid
    remove hdd tray
    remove modem
    remove esata connection
    remove backplate
    remove tuner
    unplug and unscrew the incredibly annoying fan (2 screws)
    remove the 2 pin connection from said annoying fan
    hacksaw the frame off your new fan and remove red and black wires from 3 pin plug - use the 2 pin one
    the pc blanking plate screws in using 1 hole from where esata was and holds the fan using 2 x fan mounting screws
    reassemble.....
    silent heaven
  • firestorm
    • 1550
    nice post good work
    • Superman
      • 520
      Good Alternative to the Cooling Pads here mate,
      good post, i like it.
      Super
      • temocles0918
        • Nov 2011
        Ups,, excellent modding, the bad is hard disk, not place...
        • davvo
          • Apr 2009
          • 666
          if you where to leave the small fan in there
          which spins at 12 volts which is making it noisy
          cut the 2 wires red and black then get an old usb cable join it to the 2 wires plug it in to the internal usb socket
          it will now spin at 5 volts and be silent
          that way you can still fit a internal hard drive
          • freck
            • 1076
            Bit late now Davvo
            But good advice for other DM800 surgeons out there.
            Freck
            • Curious123
              • 2591
              The fan on my clone is starting to get noisy so i was thinking of trying this solution i. e graphite powder and oil on the fan.
              Repair your noisy CPU and system fans - TechSpot OpenBoards
              • smirnoff_rules
                • 8603
                put Vaseline on mine and put sticker back on and been fine
