sky
  • griff
    • Mar 2009
    • 343
    sky
    have got a 800hd and set it up with nablio. i am about to set up a motorized dish in the nxt couple of days but thought i would connect it up to my old sky sat to try it out. now when i scan it only picks up about 94 channels namely bbc for all areas. when i scanned it i thought i would have picked all channels up ?
    is there any reason for that ? i know i wont be able to watch them i was just playing around till my other dish is up
  • Superman
    • 520
    You should get all channels, make sure the satellite.xml is up to date with transponders or try a channel list, i'll upload one if you want it.
    Super
    • griff
      • Mar 2009
      • 343
      Yeah if u could please superman. Also where do I put it ??
      When I get the motorised one set up will I need 1 for all the sats ?
      • Superman
        • 520
        Hi Mate, All you do is use Dreambox Edit / FlashWizard Pro and upload it to your box..
        I'll upload the best one i've got for you now..
        • Superman
          • 520
          Here you go matey
          Supermann!!
          • griff
            • Mar 2009
            • 343
            Cheers super will try it and let u know how I get on.
            So why will they just not scan the channels ?and will I need a list for all the other sats ??
            • Superman
              • 520
              Yeh, you can just download a full motorised list from the server on the box.
              Super
              • Adam_UK
                • 464
                Is this list of transponders on each satellite? What if more channels added/removed on a satellite after dwonloading the list? Is it enough just to do a scan everynow and then or we need to get the latest xml file ?
                • Superman
                  • 520
                  Always use the most up to date channel list available for download is my answer, will include all changes ect.
                  super
                  • dctyper
                    • 2539
                    did you scan 28 east? i done a scan yesterday and done 18 e by mistake and got 94 channels
                    Wavefield Ds 55cm at 13E 19E and 28E receiving everything out there on 2 dm800hd
                    previous life dm800hd and 500c on cable screw you nag3
                    • griff
                      • Mar 2009
                      • 343
                      just check and yeah i didnt scan 28.2e
                      just scanning it now ha
                      is there any channels out there that u can still use cams for ???
                      i know i wont pick up s#y or any other major channels i just want to try playing around with cams now
                      and thanks for everybodys help
                      super thanks for the bouquets it looks like it will save a lot of time when i work out how to use dream edit ha
                      • dctyper
                        • 2539
                        i knew you wernt scanning it its the 94 channels that gave it away
                        • Superman
                          • 520
                          Your welcome mate, as for channels the only open by cams is digitv on 1west
                          Super
