**Error in Thread description should be "R01: No CA found" ***
Hi, bit of a novice here so hoping someone can help get y box up and running...
My box - DM800HD SE Sim A8P - had an old OpenPli 4.0 image running OK, however since the whole lockdown on sly stuff it was basically running as a freesat box.
So in an attempt to get some IPTV functionality I tried flashing a new image No Links to Other Forums...which I thought would be OK but just with added IPTV stuff (as from description it seemed based on the OpenPli 4 which I was running OK...
However after flashing In getting the R01: - No CA found error. I have has similar in the past, but have at least been able to get back into the 2nd stage loader via ip address in web browser to reflash a more stable image.
However in this case I've no 'connectivity' to the box at all - when I switched the box off and While holding in front button which wold have normally brought up the IP address, this time Im just getting the above error and therefore not able to access box via web browser to reflash my old working image .nfi file. So I guess I must have done something that has corrupted some other settings.
So basically asking for help to recover the box. Is there any guides to links/tools to help with this and/or any direct cable connections from laptop to the dreambox or usb that could get the thing booting again
Any help much appreciated...
