sat moter
  • griff
    • Mar 2009
    • 343
    sat moter
    can someone help with the motor settings. i have put the tuner into positioner mode which i think is the usals ?
    but i cant get it to any sat or scan anything.
    i have had a technomate on it and moved the sat so the sat is alright. prob me and the db its a 800
  • griff
    • Mar 2009
    • 343
    or can u point me in the direction of a guide to it
      What image have you got on it m8 ? I flashed a m8s 600 last week with pli jade and it wouldnt turn my motor. I flashed my 500 with Pli jade and that woudn't turn it neither. I thought it must be something wrong with the motor so reflashed both boxes with Nabilosat and they both turned the motor. Strange or what ? Anyone, didn't mess around with them for too long. Why don't you try a couple of different images. Make sure you put your Long and Lat settings in the box m8.
      • kevin64
        • 170
        you have to sset one sat up manualy then use the usals to find the rest
        • kevin64
          • 170
          you have to set one sat up manualy then use the usals to find the rest
          • kevin64
            • 170
            Setting up a DM800 none usals
            this many help you out
            usals
            STAGE 1.
            GOTO Main Menu \ Setup \ Service Searching \ Tuning
            Press "OK" on "TUNER A"
            Use L/R keys to change Configuration Mode to "advanced"
            Move down to "SATELLITE"
            Use L/R keys to select the satellite you want to add
            Next picture
            Go down to "LNB"
            Use L/R keys to select "LNB 1"
            Next ensure "Diseqc Mode" is " 1.2"
            (I left the others at the default setting's)
            Scroll further down to "LOF" and set it to "Universal LNB"
            Next picture
            using the L/R keys
            Underneath that set "Use USALS" for this satellite to "no" using L/R keys
            Go down to "Stored position"
            Set the position you want to for this satellite to appear at using L/R keys ie 001, 002 etc and press ok
            Then Press "OK" to save the info you have inputted.
            You will need to perform this for each Satellite position you intend to set up. Before you got to positioner setup.
            Next picture
            STAGE 2.
            GOTO back to Main Menu \ Setup \ Service Searching \ Positioner Satfinder
            Go down to "Satfinder"
            Press ok on Satfinder
            Next picture
            Using L/R keys select "Predefined or Manual transponder" as required
            Go down to "Satellite" and use the L/R keys to select the Satellite to place at the above Storage postion
            Press "OK"
            When you have a lock exit this screen
            GOTO back to Main Menu \ Setup \ Service Searching \ Positioner setup
            Next picture in the next post as could only upload 5 pics here
            • kevin64
              • 170
              Press ok on positioner setup next picture
              Go up to "Tune"
              Press the "Red Button"
              Select the satellite that you had a lock on, change the transponder so it was the same as in the satfinder picture
              Next picture
              Go down to "Positioner storage"
              Use L/R keys to set the postion number that is to be setup
              Press the GREEN button to store that location
              After you have stored this position got back to satfind and change the satellite to the next one you want to view, when you have a lock on this satellite exit again and proceed with the satellite positioner again .
              You will need to perform this for each position you intend to set up in line with what you did in stage 1
              P.S. i had already put settings in so i did not have to scan any sats in.
              I hope this can help a few others out
              Have add the full file here also pdf file
              THANKS TO BRUMMIE FOR THIS WORK
              • griff
                • Mar 2009
                • 343
                kev thanks for the help i can now find the sats but it doesnt want to store the postion and when i scan the channels it doesnt do them properly ie i can only get about 6 ?
                i can use usals to move the dish now but still the scaning prob ?
                how did u get all ur setting ? a xml file ? if so could u point me in the direction of a good 1 ?
                bulldog i am using nabilosat 12 and i have put my lon and lat in and it does move ok
                • griff
                  • Mar 2009
                  • 343
                  just found this site that does all ur channels. dont know if it is any good. will try it and let u know
                  satellites.xml generator
                  • psats
                    • 823
                    why not just use the blue panel download the list online
                    • griff
                      • Mar 2009
                      • 343
                      psats didnt really know u could still a bit new 2 this ha but thanks
