web control problem
  • hwads
    • 10
    web control problem
    Hi
    When i ftp my dm800 using firefox i get this message,
    The connection was reset
    The connection to the server was reset while the page was loading.
    * The site could be temporarily unavailable or too busy. Try again in a few
    moments.
    * If you are unable to load any pages, check your computer's network
    connection.
    * If your computer or network is protected by a firewall or proxy, make sure
    that Firefox is permitted to access the Web.
    its not the firewall
    i use blackhole v 0.12 which i reflashed twice.
    dreamedit and dcc work fine,
    can anyone help
    Thanks.
  • opsmonkey
    • 5379
    are you putting in the correct IP address for your Dreambox, is the ethernet cable fully into your router and box
    • hwads
      • 10
      yes, its the one i get from the dm
      • opsmonkey
        • 5379
        log into your router and make sure the dreambox ip is static over your LAN.. make sure both ends of the ethernet cable are fully in..
        try this test..
        put your dreambox ip address in then at the end put :16001
        see if that communicates to your EMU
        eg..
        192.168.10:16001
        • hwads
          • 10
          HI, Thanks
          tried address + 16001 and it brings up cccam info page, is this correct ?
          • Tyger
            • 15
            In your router, set port forward port 80 to the Dreambox IP; it should work fine then :-)
            • hwads
              • 10
              Thanks tyger,
              just tried this, still wont work!
              Driving me mad............
              • DazMan316
                Have you tried typing in dm800.lan in the address bar infirefox? Make sure you haven't got a proxy server set too.
                Hope this helps.
                • opsmonkey
                  • 5379
                  Hope this helps.
                  please read all the answers before posting.. this has been covered
                  • 321ynnel
                    • Sep 2009
                    • 6
                    Originally posted by hwads
                    Thanks tyger,
                    I just noticed I have the same problem, worked fine the last time, no problems accessing Dreambox Webcontrol for months & months & tonight when I type in the ip address I get the same messages as you did,...I can ftp to the box no problem & can see the ip address when I login to my router, dreamboxedit works for me also,......have you found a solution.
                    I'm using a dm800, nabilosat v12 & CCcam 2.1.3
