my glitchy hd fix for 800hd
  • dctyper
    • 2539
    ok guys, i have fixed the glitchy hd channels problem. im running a clone box with bl 72. but i do have a genuine tuner. i will test on a copy one later
    what i have done
    1. flash this image, i find it the best and has full epg. Digital Kaos - Downloads - Nabilosat Enigma2 Black Hole - DM800 v0.12 FOR CLO
    2.i then installed the latest drivers
    Digital Kaos - Downloads - dm800 clone drivers
    2. fit one of these
    Inline Satellite Amplifier/Amp/Weak Signal Booster NEW on eBay (end time 02-Jan-10 04:55:47 GMT)
    any hey presto i have no problems with any channels
    all the hd channels that were working are still working and for an example. discohd has gain 3-5% snr and is glitch free. this goes with all the glitchy hd channels
    dave
  • johny48
    • 50
    Hi
    is there a guide for installing the drivers im a bit unsure on this part.
    cheers johny48
    • dctyper
      • 2539
      ftp the box and put the file in \tmp folder
      press green then yellow then manual install
      job done
      • johny48
        • 50
        job done
        thanks m8 just getting used to this enigma 2 interface thats it installed will let you know how it goes.
        cheers johny48
        • zinediner
          • 74
          Concerning the inline amplifier. Should i put the inline amp about halfway on my current cable, which would be in a crappy position or can i plug it near the reciever. Saves a lot of hassle if i can add the inline amp in the house near the reciever
          • Manic01
            • 5117
            Near receiver is fine.
            • zinediner
              • 74
              Bless you fearona you have made me happy. I have been delaying cutting the cable and putting the amp somewhere in the middle.
              • dctyper
                • 2539
                dont cut it! just get a small peice of wire. you dont have to buy that exact one. there is one that comes with a legnth of wire
                dc
                • Manic01
                  • 5117
                  This fix has been well known for a while. Doesn't fix all but a high percentage are happy.
                  • zinediner
                    • 74
                    Mine does not glitch that often to be honest. My mates does so i shall do his first
                    • gam3r
                      • 102
                      will trythisn report back
                      • satpink
                        • 121
                        any news if the above mentioned fix works for anyone else thanks in advance
                        • johny48
                          • 50
                          I would say that there is a vast improvement on the HD channels
                          so yes it does work.
                          cheers johny48
                          • gam3r
                            • 102
                            Haven't had the time to try this out yet so I will report back then.
                            • irlam
                              • Sep 2009
                              • 18
                              Worked a treat thanks for the tip...
