Motorised problem
  • satsdat
    • Aug 2009
    • 75
    Motorised problem
    Hello,ive got a dm800 motor setup 80cm dish living just outside Dublin,bought all equipment so installed myself.
    Problem as follows:
    Configured box to usals in simple mode set lon & lat
    did manual scan on lots of satellites:zero services zero channels found,checked satfinder selected say 19.2:0% signal.went outside to check motor reading degrees:spot on.Tried positioner setup to tweak the degrees to see if signal would lock on:no luck rang installer to have a look.Noticed now that i get 28e,19e,13e,9e signal 76% when i try to scan say 1w or 30w the motor moves but no signal
    went back outside to check motor noticed it was approx 10 degrees out.This upsets me greatly.All replies welcome.
    Sorry to blah blah!
  • Curious123
    • 2591
    Problem as follows:
    Sorry to blah blah!
    You have to use 'complex or multiple' rather than simple.
    • flyingpig
      • Aug 2009
      • 930
      Check your lat and long are correct as well.
      • satsdat
        • Aug 2009
        • 75
        Thx guys,i will try both your replies
        • satsdat
          • Aug 2009
          • 75
          Thanks curious123,configured to advanced settings and bang, satellites i scanned all came up.
