Dm800 an HD channel problems
  • melek84
    • Oct 2008
    • 28
    Need some help with a DM800 clone. I have been reading at the forum and it seems like all (almost) of the clones have this problem. Cant open HD channels some times + tunerfail message etc. I have bootloader v75 and gemini image. Could anyone help me with this issue as I still do not know exactly what to do? Change tuner? Change a little part in tuner? Change image or install new drives? Please some help on what do to exactly. For example first step...second step...and so on
  • NewBirth2010
    • 56
    This sounds like you have a reception problem. Check % of signal....
    • melek84
      • Oct 2008
      • 28
      thanks, I have good reception and as I change from DVBs- to DVBS2 it decrease to 0 % but that is because the channel is not DVBS2.
      • NewBirth2010
        • 56
        Thanks for thanking me. It was not actually necessary. Glad to see that you ve sorted your problem out !
        • Fergal
          • Aug 2008
          • 1007
          You could try doing the capacitor fix see if that sorts it
          • targettarget
            • 69
            I go a PANASONIC|EEEFK0J102AP|CAPACITOR, 1000UF, 6.3V | Farnell Ireland
            and its a J rev tuner. Will the fix work with the J rev of the tuner with that cap.
            • laowai
              in some new clones instaled chinese tuner, 1. with chinese label, 2. on cover no pressed ALPS, this tuners is bad sensivity, this tuners better change.
              • targettarget
                • 69
                just did the fix and its working great, still can;t get setanta though
                • melek84
                  • Oct 2008
                  • 28
                  What to do with "R7" and the other "ring" I know I have to remove c1 and replace it with "1000UF, 6.3V "
                  • melek84
                    • Oct 2008
                    • 28
                    You had Rev J, am I right? And the fix worked for you? What kind of problems did you had before? Heat problems, tune fail message, Not showing any HD channels, poor signal?
                    • targettarget
                      • 69
                      all of the above. Just still can't tune in Setanta sports now
                      • Fergal
                        • Aug 2008
                        • 1007
                        Look at the picture....you remove c1 then solder the new capictor (the big black thing smacking you in the face ) to R7 and the other ring you dont solder the new capicitor to c1.
                        • targettarget
                          • 69
                          Will be happy when Setanta finally goes under
                          • Manic01
                            • 5117
                            Only 2 channels anyway. Setanta sports and setanta ireland or rest have ceased.
                            • targettarget
                              • 69
                              yeah but Magners league and some premiership games are on it
