800HD Tune Menu
  • Sattalk
    • 66
    800HD Tune Menu
    Hi all,
    If I manually add each satellite and then go into the positioner setup then tune I can only choose 0.8 thor.
    Im unable to choose another satellite to manually peek the signal.
    any ideas?
    Regards
    Any information I provided is for educational/experimental purposeses only.
  • kevin64
    • 170
    once u press tune red button then scoll down to the sat highlight it and press your left or right button on rc to chage it to diffance sat
    • Sattalk
      • 66
      So red button that says tune press that?
      • Sattalk
        • 66
        Well I've given up doing my head in and going bald.
        What ever setting I try it eather goes past the sat or dish never moves.
        If I go into find satellite and pick one that works fine but when I try looking for one, setup the positioner nothing works.
        I've tried all sorts if images and im slowly throwing it out of the window.
        PS,
        I've never, ever been so frustrated in setting up a system in all my life.
        • kevin64
          • 170
          join the bald culb m8 god only made a few perfact heads and the rest he put hair on
          look at this file all you need to set up your tuner is in there let us no if you need any more help i am shore some one will be about ok its easy to follow step bye step
          • Sattalk
            • 66
            Thank you M8 big time.
            The above link helped me get my head around the relation between each stored satellite and the tuning per each saved position.
            This helped me resolve my problems along with finding out another.
            If I inputed my uscals position the dish would be way out so I found out after using my Technomate 1500ci that if I use 0.0000w all satellites just dropped into place.
            I presume the dish is aligned to south but no variation has been taken into account hense the reason why its slightly off.
            Anyway its working.
            Thank you.
            • Sattalk
              • 66
              And as a thank you to the forum I've just paid to become a VIP.
              Thanks all.
              • kevin64
                • 170
                well done m8 glad to here you sorted
