Flashing DM800 problem!
  • az1982
    • Dec 2011
    Originally posted by kevin64
    hi
    what you have to do
    1-run dreamup , connect DM800 with cable
    2- under dreamop select network and in the remote ip (box) put the ip you want for your box
    3-now switch on the dreambox, dreamup will prepared the box for flash
    when ready for flash
    4 take the remote ip (box) then follow the procedure through the web now
    192,168.xxxx.xxx
    will get to the upgrade firmware page
    This will force the box on bootloader mode
    I hope this will help
    Hi kevin,
    I have the same problem. HOw do you mean about in the remote to select a ip you want
    thanks in advance
    • spacey
      • Dec 2011
      This does not work for me either, selecting an own IP. Trying with the dreambo enforcer now...
      • jorgecostacv
        • Dec 2011
        • 57
        #48
        is not a valid integar
        have the same problem give this error " is not a valid integar value"
        • rschin
          • Jan 2012
          Can this also with DM800se? that use USB and with the driver you get com6
          • seenx
            • Apr 2012
            Downloaded that Dreamup and try to test it
            • aca2775
              • Jun 2012
              Originally posted by issam
              thanks a lot
              im having the same problem. what was the problem actual? previously dreamup1.3.3.4 will do.
              • DBTraitor
                • Feb 2011
                • 616
                #52
                Web browser flashing is the best for 800HD
                A wise man learn more from a foolish question than a fool can learn more from a wise answer.
                • shumi
                  • Mar 2010
                  Hi guys. I have a D.B.800se HD original. I was flushing a new image and now I get the message on the front OSD saying Ro1: no ca found. My box does not have a nini flushup on the back. tried to use dream up, but doesn't connect, tried even the browser connection and always get the same message, no ca found. Any suggestions please.
                  Thanks in advance
                  Arghur
                  • hakkou
                    • Oct 2012
                    think you so mush
                    • dreamboxjohnny
                      • Nov 2012
                      #55
                      No Ca found error. Ijust cant solve it
                      Hello. I am new user here. I have dreambox 800hd with 1 year i have flashed it a few times but now i have no ca found on front of box. It happen 3 days ago and i trying to fix it since then.
                      I have followed all the posts downloaded all the different software's and still no good. I downloaded software from here and follwed all steps. But i think my null cable is not connecting to dreambox beacuse when i use the repair part of program that error does not come up on screen.
                      Has anyone had this problem and solved it. And if i disconnect null modem and press connect it says power on dreambox but i dont have any connection going to box because just to check i untick network also. All help needed please.
                      • smoggie
                        • 863
                        #56
                        most common problem is down to the wrong drivers if you are using the usb adaptor. Best way is to use a dedicated com port on an old pc/laptop
                        • dreamboxjohnny
                          • Nov 2012
                          #57
                          I tryed using old pc with window 2000 but i could not connect that then to my internet. It is one problem after another
                          • acex
                            • Nov 2012
                            i'm the newbie here, my dreambox still have the error "R01: No CA Found in dreambox"
                            i did read thru all the steps even did try but still unable to get restore .. might my steps wrong im not sure. can anyone here provide the steps by steps gudie .. thanks and really appreciated.
                            • kengolfer
                              • Nov 2012
                              DM800SE
                              What do you do if you have bricked your DM & have no serial port on your box. I've read you camn use the min usb?
                              Does anyone know how.
                              Please help.
                              • gsmtech
                                • 264
                                #60
                                Please help.
                                yes on a dm800se you use mini usb and the service port at the back of the box. With a sim2 clone you use sunray flashup software with the usb cable for recovery.
                                Sent from my GT-I9300 using Tapatalk 2
