botloaders and sat settings clone dm 800 ..help please
  • leez
    • Mar 2009
    • 321
    hi ..i am pretty new with the dm 800 model and have been asked to get up and going ...now i have flashed with dreamup and got nabilosat on working ..but their is no 28 east ..ony 19 13 east and 30 west ..
    do i have to download through the net somesort of list or manual add a file through dcc..
    also the bootloader i am a little bit confsed about ..
    do these come in the new images aand you have to add the bootloader on some older images .. and can i get to it through dcc ..sorry if i have confused a bit ..i have only worked on dm 500 and 600 s thanks
    any help will be brill cheers .
    dreambox 800 tech 500 ( ubuntu 10 .04)... 1 m dish v box 2 acuator ..
  • kevin64
    • 170
    use the newer E2 DCC for 800 in downloads Digital Kaos - Downloads - DCC E2 v1.20
    boot loads are in image but you need to no what sim you have
    sim2.0 upto bl72 sim2.1 bl75
    you will need to setup your tuner add all the sats you wish to scan before you start the scan
    • leez
      • Mar 2009
      • 321
      many thanks kevin ,,how do i find out what sim is on the dm box thanks ..im also sort of stuck what images to use even though i wdef would not use the gemini ones ...thanks again ..
      • kevin64
        • 170
        The newer 2.01 have a sticker on the dm if not got the sticker then you have 2.0 sim or just email who you brought it from and ask they started putting the newr 2.01 in dec but rember people still have older stock to sell
        • leez
          • Mar 2009
          • 321
          absoulte fantastic thanks ..yes its got sim 2.01.. so i gather that is bl 75 .. i think ..
          so i any advice if you dont mind thanks on image .. for bl 75 ..i know hes just bought it and it had gemini on when i first set up ..
          but it tottally froze and would not respond and ive had to pick up pieces cheers for help
          • kevin64
            • 170
            Try this link m8
            RapidShare: 1-CLICK Web hosting - Easy Filehosting
            • leez
              • Mar 2009
              • 321
              kevin thanks for all your help i now know alot more about this sat reciever with your help many many thanks
              • kevin64
                • 170
                some times m8 you can just get away with flashing the bl 75 to get the image working again its here
                Digital Kaos - Downloads - clone 75 boot loader only for 2.1 sims
                • JOCKz
                  • Feb 2010
                  very interesting read. Thx guys
                  • leez
                    • Mar 2009
                    • 321
                    right cheer s.. can confirm working fine .. set up this morning ..as it had been working late last night ...but i tried to change skin and it just went into a loop boot mode ..unable basicly to handle that skin ..
                    anyway set up this morning and its all fine ...set up bouquets with dream edit . all okay thanks ...
                    i would like to make a back up of this image and i did in the menu ..but dont know wheir its went ..
                    cant find on me pc .. p s can i make a bck up on usb memory card .
                    just in case .. and meaning i dont have to flash all the time ...many many thanks ..
                    • mblaauw
                      • Aug 2009
                      ja hoor zal wel
                      • jitong
                        • Feb 2010
                        • 5
                        These files are the same as offical ones what can be aquired here:
                        installable software packages for dm800
                        File name:
                        dreambox-secondstage_75-r0_dm800.ipk
                        As i so far know, clone needs patched ones even if you have sim 2.0.1? Please correct if i'm wrong.
