buying 800hd what needs too be flashed on it before i add a c line config
  • psxchipper
    • 35
    i was going too buy some clone 800hd boxes and was told i have too flash them can any1 tell me what files have too be flashed to the box, so when i add a c line config they will work
    plus if i add a hard drive too them will i have too do anything else
    thanks as allways
  • baboon99
    I prefer the nabilosat 0.12 as its easy to download the plugins to get it up and running.
    You need the box connected to your router with a static ip address, and port forwarding 12000 setup to static ip of dreambox.
    Check here for clone safe images.
    h**p://dm800sim2.com/sim2/index.html
    other tuts here h**p://dreamboxclones.co.cc/category/tutorials/
    Once image is intalled press to get the addons menu in Nabilo images press the green button then the yellow button. Select Download Manager then Cams
    Select CCcam 2.13 or 2.14 its your choice, and install.
    Then download dreambox control center from the internet and install on ya pc, version is 2.95 I think
    Its got a ftp client within the proggy connect and go to
    /var/etc
    If you have installed cccam there should be a default cccam.cfg file there, just right click and edit this file and add your cline.
    Box should be working now.
    I have a default cccam.cfg file if you want it just pm me.
    Hope this helps.
    G
