Hi guys, can anyone help me? My dreambox was working fine before but now i get tune failed on every single channel, even the free ones like bbc?
Tune Failed on every single channel?
Sounds like tuner has failed, i have also seen this were the image is corrupt and flashed new image and tuner was fine...
if i was you select tuner 28.2e simple mode single sat and try scan and post what you get from there then we can help further to find your fault, but where you say you changed the tuner im sure it will be image fault as i seen this once beforeComment
Yeah your tuner is Gone I would say , Even if your satellite dish has moved you would still see some sort of signal strength between different satellites had it moved.
Pluse you have not told us what Model Dreambox you have ! & is it a Clone or a real one.
Clone receivers have a tendency to pop there Tuners.Comment
Well the Voltage or components used by the manufacture of clone receivers might (most likely) differ from an original Dreambox, there simply could be a too big a differance between Voltage or something else between a clone tuner & original, you might have blown something by trying it.
Clone receivers are made with alternative materials making it cheaper than the original Dreambox, A clone is not 100% the same especially when it comes to interchangable parts.Comment
Do you have access to another receiver to check with? or possibly a satellite meter?
Try and connect it up to a working Sky Receiver. If another receiver cannot receive a signal then it's definitely your dish or lnb thats the problem.
If however another receiver can get a signal then your DM is knackered. Reflash it would be a good start.Comment
