Cccam not working anymore
  • SAFC_FTM
    • Sep 2009
    • 51
    Hi guys,
    I've edited my cccam.cfg files tonight on my dm800 using DCC as i have a new share on a server.
    When i've gone into NabiloCccamSwitch and activated my new config everything has died, obviously i thought it was my new server so i went back to my old cline (which was working up till i activate dthe afore mentioned config) and that was also now not working.
    I have gone through Ccam settings and it is showing correct clines but for some reason cccam does not seem to be playing ball any more.
    Any one had this before? If so how did u resolve?
    BTW it is Cccam 2.1.4
    Cheers
  • felix1
    • 211
    cant chat about c/s on here. however, what is NabiloCccamSwitch? and why do you need it? just restart your cccam after any chances to config file.
    • SAFC_FTM
      • Sep 2009
      • 51
      hi mate,
      will keep the c/s side of things out of it.
      but basically i have a 2 cline that works.
      NabiloCccamSwitch basically allows you to have upto 5 seperate cccam.cfg files and enable whichever one you want through the dm800 OSD rather than having to ftp the change. All it does is dump your selected .cfg file into the master cccam.cfg
      When you say restart cccam what do u mena by this? do u mena just go into the blue panel and press activate again on cccam 2.1.4?
      I've done cline changes before and never had this problem?
      • deffc0n
        • Aug 2009
        • 894
        Hi
        I have only Gemini 4.7 for me the best image i have CCcam 2.1.4 all satleites work very fine maybe you change image ?
        I edit config Notepad + and send for ftp TC.
        BR
        • SAFC_FTM
          • Sep 2009
          • 51
          Originally posted by deffc0n
          Hi
          BR
          I've used Nab BH012 for a while now and changed clines before without a problem, i did reflash my dm800 with Bh012 again and this still hasn't resolved the problem.
          May try Gemini image but don't really feel this is the problem, just seems that cccam is not running correctly or hasn't restarted???
