Can not tune any sats other than 13E and 19.2E
  • dazv
    • Apr 2010
    Hi Am new to this forum and the DM800HD. Am using the NabiloSat Blackhole image (latest). When trying to tune I can only see 2 satellites 13e and 19.2e. Q1 is How do I add other sat's? and am going to setup a motor so Q2 how do I tune in using a motor. Cheers in advance.
  • westkill
    • 2378
    what dish setup you got ,is it a motorised dish ?
    • jdunlo
      • Mar 2010
      • 13
      follow this mate iv taken it from a tutorial with pictures but iv omitted the pictures. i am not the author of the tutorial
      guide to setting up your DM800 tuner
      Image Used - Blackhole V0.12
      If your using DiSEqC 1.2 you will have to set-up the dish positions manually. If your usuing USALS
      it should be automatic.
      Here's the USALS procedure that I used on mine
      First make sure the dish is correctly aligned on a satellite, eg Astra 28.2e
      Press Menu
      Set Up
      Service Searching
      Tuner Configuration
      Choose Tuner ALPS BSBE2 (DVB-S2) - Press OK
      Now for my configuration??..
      Configuration Mode: Advanced
      Satellite : Astra 2A/2B/2D/Eurobird 1 (28.2e)
      Change LNB to LNB 1
      Priority : Auto
      LOF: Universal LNB
      Voltage Mode: Polarization
      Increased voltage: yes
      Tone Mode: band
      DiSEqC Mode: 1.2
      Toneburst: None
      Committed DiSEqC: None
      Fast DiSEqC : no
      Sequence repeat : no
      Command order : committed toneburst
      Uncomitted DiSEqC command : None
      DiSEqC repeats : none
      Longitude: Set this to the correct Longitude for your area.
      To find the correct longitude settings for your area go to the following website
      Worldwide map search, route finder and travel directions - powered by Multimap
      In the "Find a Map" box at the top left of the page, enter your post code.
      Select your country in the drop down box below it and click on the "Find" button.
      This will display a map on the screen and below the map at the bottom right you
      will see your Latitude information, example below for Postcode district:NE39 1
      Lat:54:55:09N (54.91913)
      Lon:1:44:55W (-1.74859)
      So in this example in the Dreambox menu you'd set
      Longitude: 001.748
      West
      Latitude : 54:550
      North
      Use USALS for this Sat: Yes
      PRESS OK TO SAVE
      Once this is set up on one satellite its easy to sort the rest.
      Go back into reception settings
      Highlight satellite and choose the satellite you want
      The example here shows Hellas on 39.0e
      Now select LNB and change to LNB 1
      This will fill in the configuration with your previously set configuration
      PRESS OK TO SAVE
      Repeat for the other sats you are looking to pick up
      • network-nt
        • Apr 2010
        • 26
        I think you'll find it was pre-setup. If you run a factory reset, you'll be able to select any satellite you want. Hope this helps!
        • kamel22
          • Jun 2009
          • 42
          Press Menu
          Set Up
          Service Searching
          Tuner Configuration
          Change LNB to LNB 1
          Priority : Auto
          LOF: Universal LNB
          Tone Mode: band
          DiSEqC Mode: 1.2
          Toneburst: None
          Fast DiSEqC : no
          Longitude: 001.748
          West
          Latitude : 54:550
          North
          PRESS OK TO SAVE
          PRESS OK TO SAVE
          Im new to Usals settings. what happens after pressing ok to save.will the dish scans automatically or i need to do something. thanks in advance.
