Dm800 setup guide
  • fay28
    • 66
    Dm800 setup guide
    hi guys
    further to my experence in using a dm800, can i suggest hat someone draw up a setup guide for new users?
    i hear you have to put in the long at lad details etc which i found abit confuseing.
    im looking to get another dreambox soon but a guide would be useful to me and evey other new user.
    Thanks in adavance
  • westkill
    • 2378
    are you using a motorised setup ?
    If your using DiSEqC 1.2 you will have to set-up the dish positions manually. If your usuing USALS it should be automatic.
    Here's the USALS procedure from memory (someone please jump in and correct me if I've made any mistakes)
    First make sure the dish is correctly aligned on a satellite, eg THOR 1W
    Press Menu -> Set Up -> Service Searching -> Tuner Configuration
    Choose Tuner
    ALPS BSBE2 (DVB-S2) - Press OK
    Configuration Mode: Advanced
    Satellite : THOR 1W
    Voltage Mode: Polarization
    Tone Mode: band
    LNB : LNB 1
    DiSEqC Mode: 1.2
    Use USALS for this Sat: Yes
    Longitude: Set this to the correct Longitude for your area.
    To find the correct longitude settings for your area go to the following website
    Worldwide map search, route finder and travel directions - powered by Multimap
    In the "Find a Map" box at the top left of the page, enter your post code.
    Select your country in the drop down box below it and click on the "Find" button.
    This will display a map on the screen and below the map at the bottom right you
    will see your Latitude information, example below for Post Code NW1 UK :-
    Lat: 51:31:59N (51.53319)
    Lon: 0:08:40W (-0.1445)
    you may have to miss last digit
    So in this example in the Dreambox menu you'd set
    Longitude: 0.1445
    West
    latitude: 51.53319
    north
    • gibson
      • 14
      I don't want to highjack this thread, but could we go further into this proceedure?
      Two days ago had delivery of a DM 800 Clone and have got as far as installing Enigma 2 Flash.
      I'm extremely unaware of the process to achieve a fully functional DM box, but I believe I have to now instal an EMU?
      Following on from the above how do I do this and what do I need regards cables, etc.
      Also, what is the setup re: TV, DM 800 and PC in a schematic sense to download an EMU?
      Mods feel free to move/amend if you feel this dosen't follow on from the original request.
      Best wishes from,
      Gibson.
      • kamel22
        • Jun 2009
        • 42
        Guys, any guide for setting up salellites dm800 manually (non USALS) Thanks in advance.
        • jumpinjo
          • 869
          Best wishes from,
          Gibson.
          now you got image bud you can download and install emu/cccam with box online from addons either blue yellow button on remote
          • jumpinjo
            • 869
            try this bud
            • gibson
              • 14
              Thank you jumpinjo, will give it a try.
              Best wishes from,
              Gibson.
              • kamel22
                • Jun 2009
                • 42
                Originally posted by jumpinjo
                try this bud
                jumpinjo, i can not view this file it says damage.
                • jumpinjo
                  • 869
                  its working bud for others
                  • fay28
                    • 66
                    thanks for the replys guys,
                    guide required for fixed sky dish
                    • gibson
                      • 14
                      bigupload format not working for me. Thanks anyway for the try.
                      Best wishes from,
                      Gibson.
                      • jumpinjo
                        • 869
                        can anyone else confirm if both links dont work as it would be very strange
                        • bugaloo41
                          • 1598
                          Joe the rar file you posted works fine mate. Bigupload appears to be in a loop though and wont let me access.
                          • jumpinjo
                            • 869
                            thank you boogy
                            • gibson
                              • 14
                              Picked up the set up tuitorial, very usfull jumpinjo.
                              Not sure how to instal EMU via buttons though. Screens look unfamiliar and not sure what to put where. Any help appreciated.
                              Best wishes from,
                              Gibson.
