sky uk entitlements
  • dctyper
    • 2539
    sky uk entitlements
    so my entitlements ran out today, my sky uk card has been in my dm800hd for months, i thought it auto updates?
    anyway i have been told to put this line in
    DISABLE EMM : no
    will this mean in will auto update now? how long does it take?
    dc
    Wavefield Ds 55cm at 13E 19E and 28E receiving everything out there on 2 dm800hd
    previous life dm800hd and 500c on cable screw you nag3
  • dctyper
    • 2539
    cum on guys
    im stuck
    dc
    • bubbles69
      • Feb 2010
      • 1146
      what version off cccam have you been running? and you had it in your slot of dm800 and the card has not received any EMMs??
      its not because of the no on the end of clines..
      • dctyper
        • 2539
        running 2.1.3 i thought i didnt need the yes/no if i had this line
        DISABLE EMM : no
        so, i should ajust my cccam f/c lines then?
        how long does it take to update?
        dc
        • bubbles69
          • Feb 2010
          • 1146
          that line should be hashed out ie
          mine is..
          #DISABLE EMM : yes
          you can also add allow emm in one of your flines someone that is on 24/7
          1 0 0 { 0:0:2} { } { }
          to
          1 0 1 { 0:0:2} { } { }
          this will allow emm from client
          • tvadict
            • 363
            1 0 1 in f line is the sure way to receive emm. ccam 2.1.3 is needed for this. It can take 1 minute or 24hrs. Usually 1 EMM is enough to update the whole entitlements.
            • felix1
              • 211
              not too sure about this but i dont see why you shold be relying on emms from another peer. shouldnt it be automatic with cccam 2.1.3? i have never had to change anything and ive recieved all my updates.
              are you using an upto date config file?
              edit: actually just checked my config file and its not even in there. but i havent had to change anything. that was all with 2.1.1 im sure.
