dream 800 help please
  • billy2
    • 1381
    hi all just got my 800 yesterday with Gemini cams and figs on it, put my bits and bobs needed to make things work did my channel scan got all channels all good so far now for my prob my hd channels doing my head in bracking up every 20-30 secs, the snr is at 82% on slysports hd1 and the AGC is at 99%i also pickup an inline amp so tryed that now the snr drops to 62% can anyone throw any light on this please the box was got in uk a clone and has the l3 tuner in it i hope
    cheers
  • bubbles69
    • Feb 2010
    • 1157
    Wrong in-line amp,In line amp does the job m8 you just need the correct one, but you must check ECM times also as alot of people get confused with working out witch is the cause of glitching, just check ECM time soon as the channel glitches if its not that you'll need the inline amp..
    • billy2
      • 1381
      dont think the glitching is down to ECM as it is non stop as for the amp the one sent with the box is a 13-18 db got from the uk shop you say you got your box from
      • billy2
        • 1381
        ok just flashed with nabilo to try this, when i go to tuner comfig it is say nothing connected can anyone help please (img used NabiloBlackHole-12-SIM201e-BL75-dreamboxclones)
        cheers
        • bubbles69
          • Feb 2010
          • 1157
          download images from below,
          the images from the other site dreamboxclones i heard someone else had issues with the images from there saying it had a bomb in but didn't think there was bombs in dm800 images
          I have no problems from here..
          Free Dreambox Images Download (Only for NEWB DM800 SIM2)
          • Curious123
            • 2591
            cheers
            When configuring the tuner select 'Simple' and then on the Disq select 'positioner ' if you have a motor.
            • billy2
              • 1381
              have to say found this img (sim201e-75-OE16-DreamEliteBH-124-DM800-2010405.nfi) from the site above alot better than the Gemini one on the box
