protecting dreamboxes
  • scoot1690
    • 90
    hi guys can anyone please tell me how to completely secure a d800 i changed password in telnet twice but someone is still hacking my box help is appreciated thanks in advance
  • Curious123
    • 2591
    You could try the Pli image which gives you the option of installing a firewall.
    • manxspud
      • 1768
      Hi m8...
      1st two things i would do are :
      1... check your routers security. if your router uses wep it can be hacked very easily. if you have the option to use wpa / wpa2 then use it.
      2... is your router using the default admin and password for login.. ie... a netgear router uses admin and password for the defaults. If so change them.
      trust me when i say its possible to access your network if it is set up in this formate. if both of these are secure then i am at a loss. and hopefully somebody ealse can help'
      good luck @manx
      • bubbles69
        • Feb 2010
        • 1150
        What do you mean by hacking what part of the box is being accessed? and what changes are being made to make you say someone is getting in?
        • scoot1690
          • 90
          sorry i didnt want to say too much as cs talk is banned it was to stop someone hacking into my box for certain things hope i havnt broke any rules and apologies in advance if i have
          • bubbles69
            • Feb 2010
            • 1150
            change your ftp password that's the only way in to edit the .cfg, once password changed no one can get in
            telnet in and type passwd
            then its changed no one knows it apart from you
            • scoot1690
              • 90
              tried it twice already mate maybe it might be something in my router i secured it earlier and i put the password in twice as well to make sure
              • scoot1690
                • 90
                forgot to say using a netgear dg834gt i think the problem is in dmz
                • schmucker
                  • Apr 2010
                  im upgrading my account
                  yea free the dreamboxes
                  • bubbles69
                    • Feb 2010
                    • 1150
                    Even if they could get in your router they cant get in your dreambox if you changed the password there is no other way in,,
                    have you tested that root and dreambox don't work???
                    • scoot1690
                      • 90
                      trying it again bubbles
                      • scoot1690
                        • 90
                        changed the password again how how can i tell its 100% secure thanks for the help so far guys
                        • bubbles69
                          • Feb 2010
                          • 1150
                          does root and dreambox not work then????
                          • scoot1690
                            • 90
                            no its been changed root and dreambox dosnt work anymore
                              If your new pass works then thats good
