Dummies Guide?
  • PineappleSorbet
    • 16
    Dummies Guide?
    I've never owned or used a Linux reciever before. However, I'm expecting one tomorrow, and I want to get familiar with the software etc before I install tomorrow.
    From what I understand, it comes preinstaled with: 'Bootloader 75 Gemini 4.60, SIM version 2.01'. Is this OK? Do I need to update? Does a new version exist?
    Am I able to use streaming to PC with the above software? I'm hearing about 'blackhole' is that better?
    Kindest Regards,
    Is it the Dm800 clone your getting ? Yes you can stream ok with the installed image. I would change it to Nabilosat blackhole, which is available in the downloads section. Make sure it's the one for clones, assuming your is a clone
    If and when you flash your new image, do it via your web browser. It takes about two minutes as opposed to an hour using Dreamup.
    • PineappleSorbet
      • 16
      It must be a clone; for the price I paid, it has to be.
      I'm downloading the images now How does this install business work? I take it web interface is enabled as standard? Do I need to enable anything?
      I've seen other posts mention Linux commands etc
      And before anyone accuses me of being an idiot, I did say I'm after a dummies guide.
      • Curious123
        • 2591
        If you have never used a dreambox before and you are hoping to get to grips with a dm800 then you may have your hands full. This manual might help you with your box;
        • mkhairym
          Thanks!
          • PineappleSorbet
            • 16
            OK. I got it working. Needless to say, it's actually incredibly simple.
            I'm not sure what software actually came installed on it, but it's a doddle. For example, I was under the impression I would need to do a lot of tweaking for the bouquet lists to work. In fact, however, all I had to do was install DreamBoxEdit, change my FTP to match the IP of the box, selecting 'v3' and it did the rest. I need the 'WebControl', as I can then manage schedules when I'm away, and guess what, it was already there, I had to simply 'enable'. As for CCCam, it must have also been preinstalled. I simply moved my CCcam.cfg across and it automatically read and connects.
            Despite having a clone and hearing the horror stories of overheating, picture breakup and constant locking: I'm not having any problems. My box is actually incredibly cool. Plus, ALL HD channels work without a problem and SNR ranges from ~55%-70%.
            I don't have a 2.5" drive but I do have a 3.5" and a USB adaptor. Installing that was easy too. Just plugged it in, 'initialised' from the blue menu, and then used the one-click 'syslink'. It now records fine also. I'm loving the FTP file transfer. However, only problem is the speed. I'm getting ~5.5MB/s and when the file is around ~12GB it can take a while. But it's worth it. Unlike my old cable box, it records all the audio streams. So AC3 and MPEG.
            • freck
              • 1076
              Fair dues for sorting it out,your an old hand at this I can tell.
              Took me ages to find out what you know now,well done
              Freck
              • manxspud
                • 1768
                Glad to hear your up and running. i must admit that i have only changed over to a dm500s in the last few weeks, i was also expecting it to be a lot harder than it was. Its down to the members of this forum that make things a lot easier for those that are prepared to do a bit of reading.
                thanks to all those that take the time to answer posts, and share their knowledge. @manx
