Im swapping my clone 800HD for an original and want to flash it with a decent recent image. Does anyone have an original 800HD? Will the drivers get updated with a newer image and does the sim get updated also?
Best done by browser,dreamup takes 62 mins approx.
Why you changing your cloned unit??the original is pricey and both do the same job.
Freck
The original Dreambox 800 can take the very latest image and drivers without any hassle.
Also the internal components are better quality on an original. I am exchanging my clone for an original for ?135
How are you finding this box to use? I'm considering this one or the 500HD which has an HDMI connection, useful as it carries sound also. The 800HD has pvr capabilities which may be useful i guess.
i have dm800 but i find watching hd stuff over home network in my experiance cant stutter and pixalate a bit , sd is ok i find
so with an 500hd u would need a good network running i guess for this to get the best out of it
only problem with originals is they get to hot..!!! i had to leave mine on its side to keep cool, my clone runs alot cooler than the orig..
Im about to order a Dreamcooler for mine. That will bring the temperature down.
Do you have any noticeable differences between your clone and original? do you have a continous steady picture on HD channels on your original?
The DVI port on the 800 also carries sound btw , no need for seperate cables !
bub
i have dreamcooler for my original and nothing for my clone, both work perfect on HD channels, i do use the in-line amp with the clone
