Images for clone DM800 BL75
  • iKay
    • Apr 2010
    • 182
    Hey all,
    I have DM800 clone with BL75. It was shipped with Gemini 460 (which I don't trust). I've been trying to install different image on my box (not multiboot). With everyone i tried, i get "no CA error". Only Gemini 460 & 470 worked.
    I have tested the below images so far:
    - NabiloBlackHole_DM800_012
    - DreamEliteBH_DM800_124
    - DreamEliteBH_DM800_124_SSL75_TSv2
    - DreamElite_dm800_bl72 (as suggested by one of the users here)
    - PLi-enigma2-jade3-dm800
    My question is:
    What are the WORKING images for my box? I can't trust Gemini. Also, I'm new to DM800, so i'm going through the change factor already.
    Thanks in advanced.
    Last edited by iKay; 10 May, 2010, 16:39. Reason: Added another unsuccessful image
  • iKay
    • Apr 2010
    • 182
    This one seemed to boot normally. I'm going through the initial setup now
    DreamEliteBH-124-DM800-sim201e-75-OE16
    • fish77
      • May 2010
      • 11
      i've got a dm800 on order and should have it tomorrow, anyway that's the image i've been told to use by a couple of other people
      can you let me know how you get on with it?
      • iKay
        • Apr 2010
        • 182
        so far i've been using it for less than an hour, and i find it really amazing. I got lost at the begining till i flushed the Gemini cache from my head
        I got a little bug in the Simple skin ,, it hangs a bit and it is not aligned right.. im trying other skins (i love things simple).. but other than that, i feel the image is better than Gemini
        plz note that im just using it for short time
        • fish77
          • May 2010
          • 11
          cheers mate
          • bubbles69
            • Feb 2010
            • 1150
            as requested via pm,,
            RapidShare: 1-CLICK Web hosting - Easy Filehosting
            dreamelite 1.3
            • iKay
              • Apr 2010
              • 182
              Thanks mate. I'm still exploring DreamElite BH 124
              I ordered 250GB SATA to install it internally. I will give BH130 you provided once i'm done with that.
              • iKay
                • Apr 2010
                • 182
                dreamelite 1.3
                This worked prefectly on my box
                • iKay
                  • Apr 2010
                  • 182
                  I have one concern though.. when i login to the web interface and check the info, i found this
                  Device & Versions
                  Devicename: dm800Enigma
                  Version: 2010-04-15-experimental
                  Image Version: Experimental 2010-04-19
                  is it normal to show "experimental"?
                  • bubbles69
                    • Feb 2010
                    • 1150
                    All images are experimental, thery are all customised enigma 2 images..
                    • iKay
                      • Apr 2010
                      • 182
                      is it possible to install one image only on internal SATA instead of the internal flash?
                      • karlsson1122
                        • May 2010
                        Hallo!
                        I have new DM 800 Clone and I have tryied gemini 4.6 dose not work for me. I use dreamup ang it will go to 100% then I got the error code 002.
                        Can I get this to work?
                          Have you tried flashing via your web browser instead of using dreamup. http://www.digital-kaos.co.uk/forums...browser-55296/
                          • fish77
                            • May 2010
                            • 11
                            how do you access the blue panel on dream elite 1.3?
                            everything i've read says the blue button but i get Black Hole Settings when i press it, i've tried different combinations with other buttons but can't find it
                            edit: sorted it, must've been the skin i was using as i changed skin and it worked straight away
                            • iKay
                              • Apr 2010
                              • 182
                              Yes i noticed that the buttons functions differ in every skin.
                              I'm using BlackShadow L skin, which i feel so comfortable using it.
