erro No CA found DM800
  • Tareq966
    Hello,
    I have a problem with my Dreambox 800. I had the Gemini 4.6 bootloader 75. I tried to flash it to 4.7 using internet browser. I connected my dm 800 to router and my pc too. I uploaded the flash I got to dm800. After it was completed I got this message "Error no CA Found" I can't connect anymore to my dreambox. I tried to hold the on button but is still did not work please advise. Thanks
  • Tareq966
    The dreambox I got is the one from china.
    • Curious123
      • 2591
      Originally posted by Tareq966
      Hello,
      Have a read here;
      • iKay
        • Apr 2010
        • 182
        I went through the same last night. To recover your box with Gemini 470 image do the following:
        1- Download Gemini 470 BL75 from Here
        2- Connect your box through cable.
        3- Run DreamUp, choose COM1 and Enable network and configure the IP addresses. (to install the image in two minutes. Otherwise just use COM1 without network, but it will take around 61 minutes to flash the box)
        4- Click Connect and power on your box.
        5- Once the DreamUp is ready, open the browser and type the IP address of the box
        6- Click "upgrade firmware" and browse to the downloaded Gemini 470 NFI image and click flash
        This should be done in couple of minutes, then just disconnect your DreamUp and reboot your box
        the key is to use the right image. I have started another thread for testing several images. You might need to take a look at it
        • westkill
          • 2378
          yes i have used this method on a clone does work
          • Tareq966
            Thank you very much it did work.
            • benalla
              Hello iKay,
              I had the same problem so I used your way and image as suggested. Flashing gave no error/problems.
              But after powering off and on the box kept on booting, again and again.
              Tried to power off and on some time with no result.
              Do you have any idea?
