file to big not fixed
  • abualferas
    • 18
    dm800 and dreamup all ver. could not talk to each other even with the enforcer
    I tried all the lead but no solution now the light of the ethernet went blank "no light" if any one solved thi prblem please post for me and the others with same problem
    I am sorry but had this problem and comunicate with the expert in this forum but no solution till now
  • bubbles69
    • Feb 2010
    • 1150
    have you tried the patched dreamup witch i posted a few weeks back..!!
    • abualferas
      • 18
      yes but not working I'll com with solution
      • bubbles69
        • Feb 2010
        • 1150
        what does the display say? the dreamup i posted puts it back in flashing mode if you have no CA error, what error do you have?
        • abualferas
          • 18
          it bootuo till the end then transparent bar under it is 3:03
          • bubbles69
            • Feb 2010
            • 1150
            sounds like wrong image installed for bootloader, can you flash via webshell still?
            or are you saying its stuck on first screen dream multi media?
            • johnleo
              • 13
              I have a similar problem with my DM800HD. When switched on the display shows "Error". With a serial cable I try Dreamup and get the message "No CA found...". With the enforcer I can try to flash but get the message "File too big" even if it is the smallest file I can find.
              Any suggestions?
              John Leo
              • bubbles69
                • Feb 2010
                • 1150
                Can't understand why you guys are trying to flash the file through dreamup, you just use the patched version i posted a few weeks back and connect null modem connect to dm800 this will then put it in flash mode display the ip of the router you are connected to then on pc type the address displayed on lcd and flash..
                • johnleo
                  • 13
                  Hi Bubbels69
                  I have already tried a patched version that did not work. Where can I find yours? I have searched for it but been unable to find it.
                  • bubbles69
                    • Feb 2010
                    • 1150
                    i have repaired lots of no ca with the patched version i posted,, where are you getting stuck?
                    • johnleo
                      • 13
                      The patched version I used was called
                      DreamUP_patched_by_forhike_and_natas.exe.
                      Is it the same one you posted?
                      • johnleo
                        • 13
                        When I use this patched version of Dreamup, I get the message about NO CA FOUND and I cannot flash. When I click on OK Dreamup disconnects. Dreamup shows the same IP as the lcd.
                        What else can I do?
                        • bubbles69
                          • Feb 2010
                          • 1150
                          all you use dreamup for is for the first boot,
                          click connect
                          power on box
                          wait for it to initialise
                          once ip is displayed on dream box don't touch anything else on dreamup that is all you need to touch,
                          go to pc or laptop that is connnected to same router as dreambox then type ip 192.168.**.**
                          the flash thats it fixed.. i have done many no ca for people..
                          • abualferas
                            • 18
                            Hi I left the box of for 12 hrs then started again and again many time but when you power off the box keep it off for at least 10 second till the box giveup and respond to you after many time of trying
                            dont giveup
                            • johnleo
                              • 13
                              I have done exactly as you say but explorer cannot connect to the box. I just get a mesage about site not found.
                              I have tried it from 2 different PCs.
                              Have you got more ideas?
