I have a DM800 Clone which I have some troubles with. I look very much on Viasat 5E and Canal Digital 1W. But my receiver freezes on these channels after 1-2 minutes ( TV2Sport (HD) TV3Puls, TV3 HD, TV1000HD. I use Gemini 4.2 because it is the only one which is working, with subtitles on HD channels. Why is these channels freezing.
freezing on HD channels, dm800
This topic is closed.
Tags: None
You must check your ECM time if ECM is good then you need one of these..!!
IN-LINE AMPLIFIER FOR DM800HD WITH WEAK DISH SIGNAL INC PATCH CABLE - ukdreamshop -
my ecm is over 90, so I don?t think it is because of weak signal. My best friend has the same supplier and his DM800 is working perfect (he says). His is an original and mine is a clone, is that the cause to the problem. The problem has not always been there, but has come for the last 3 weeks.Comment
you gettin mixed up between ecm and signal mate ?my ecm is over 90, so I don?t think it is because of weak signal. My best friend has the same supplier and his DM800 is working perfect (he says). His is an original and mine is a clone, is that the cause to the problem. The problem has not always been there, but has come for the last 3 weeks.
Sounds to me like you need a inline amp. There are quite a few out there. I first bought one which did not fix it properly, i then bought another And it worked perfect. The one which worked was from ukdreamshop, it is linked to above. Atleast you will know it works mate.
___________________
In the good old days, I hadDM800s HDOpenbox S10
TM500
DM500s
90cm FortecStar dish
Maxx 110cm Dish
Technomate 2300 Motors
sigpicComment
Ok, this is what I have noticed. The ecm is about 0.500-2.000 when it is working perfect, but when it freezes there is no ecm. Does this mean that my supplier has a problem or that I have to buy an inline amp.Comment
I am watching Viasat 5e and the most problems is from this. satellite. Last night I could not see them at all, but this morning they are working again, no problem today yet. The problem is with these channels, TV2sport and HD, TV3 Puls, TV3+HD, TV1000 HD, other viasat channels is working perfect and not freezing. They freezes in 20-30 sec, comes again 1-2 min and freezes again. I dont think I have a weak signal, because snr and agc is about 85-100 %. OH, now dissapeared tv2 sport (black screen). Very irritating problemComment
yes the url and ecm dissapears. Does this means that it is my supplier that cut me off and him that has a problem.Comment
