Tuner failing
  • abynk
    • 35
    Tuner failing
    Hi,
    My DM800HD was working fine with gemini4.6 , I am using diseq with eurobird9 and astra 28.5 . this afternoon while i was watching a channel picture disappeared and "channel could not be found check tuner configuration " message came on screen. I have tried to change tuner configuration in setup but in the satellite names I can only see nothing connected in both DiseqC A and B . Tried replacing satellites.xml but still showing nothing connected.
    Then I have flashed the box with dreamelite Blackhole image , everything worked after a scan and all.But after about 2hrs picture disappeared and "channel could not be found check tuner configuration " message came again. Reflashed and working fine now.
    Any Suggestions?
  • westkill
    • 2378
    does it happen on both sat when zapping channels
    maybe diseqc switch
    need to uliminate every thing from dish to box
    • abynk
      • 35
      maybe diseqc switch
      yes on both satellites. connected old technomate box and showing signals on both satellite also in dm800 it is not letting me to change satellite names. So I think it is something to do with the box than anything else.
      • westkill
        • 2378
        just a thought is the tuner lose inside the box ?
        • deffc0n
          • Aug 2009
          • 894
          Chcek revision tuner inside box i think tuner is dead.
