smargo
  • tab99_uk
    • 227
    smargo
    just recived my smargo having trouble setting up followed all guides still cant get it going having trouble installing the nabilo drivers in dreambox dm800 i have ftped the nabilo drivers in temp folder but when i go to install them in maual install theyre not their.
    im using dream elite blackhole image 13 i could get internal card reader working without a problem but cant get the smargo working i have updated the firm to 1.4.
    im using dreambox config creator to make the new cs file
    been on this for a few hours without any luck now
  • westkill
    • 2378
    never used one but...
    try
    blue button>extra setting>kernal modules manager
    for active modules
    • bubbles69
      • Feb 2010
      • 1150
      If your using cccam you need a line to point to the device like
      and a line to point the boxkey
      SERIAL READER : /dev/ttyUSB0 smartreader+
      BOXKEY: /dev/ttyUSB0
      • tab99_uk
        • 227
        where do i add this in cfg file.
        • bubbles69
          • Feb 2010
          • 1150
          anywhere you like, 90 % of the standard config lines are not used anyway.. just replace the part that points to the internal reader so it points to the usb
          • tab99_uk
            • 227
            do i add the boxkey in the cfg? i treid with the boxkey and without it still no luck enabled kernels moudule chipset ftdi yes added the boot file. bootup in the folder /ect/init.d
            yo add the line below.
            echo 90 > /proc/progress
            modprobe ftdi_sio
            still getting anywhere tried nablio 12 image now still the same wtf going on been on this for 2days now.
            • tab99_uk
              • 227
              my cfg file
              # This file was created by Dreambox Config Creator by B16MCC
              SERVER LISTEN PORT : 12000
              N: 192.168.2.8 15000 User1 User1 01 02 03 04 05 06 07 08 09 10 11 12 13 14
              N: 192.168.2.8 15003 User1 User1 01 02 03 04 05 06 07 08 09 10 11 12 13 14
              SERIAL READER : /dev/usb/tts/0 smartreader+
              • bubbles69
                • Feb 2010
                • 1150
                are you not using CCcam that looks like newcs lines..?
                • tab99_uk
                  • 227
                  yeah using new cs 1.67
                  its detected the smargo in box card shows up in cccam info still not clearing any channels my smargos a orignal so no problems updating it or downgrading it.
                  • piopat
                    • 708
                    did you put the smargo in dreambox mode ,run smartreader.exe and change the kernal settings to dreambox and click on apply .if your using vista when you clicked apply it may not have worked ,i had to do this on an windows xp computer as clicking on apply would not work on my vista laptop.
                    • bubbles69
                      • Feb 2010
                      • 1150
                      Why not just use cccam easier to setup.. problem with new cs is and does not allow EMM's so card entitlements will not update..
                      • tab99_uk
                        • 227
                        got it working guys i was uisng new cs instead of cccam2.14 but uisng nabilo blackhole 12 i want to use it with dream elite image but cant get it to work is thier any drivers for dream elite image??
                        • bubbles69
                          • Feb 2010
                          • 1150
                          aLL DRIVERS ARE IN THE DREAMELITE IMAGE ITS ALL TO DO WITH THE LINES IN THE CCCAM.CFG JUST USE SAME CONFIG THAT YOU HAVE WORKING IN THE NABILO
                          • tab99_uk
                            • 227
                            thanks got it working in the end the cfg file was a bit diffrent got dream elite.
                            thanks for all your help guys
