was going to change image but
  • Wingnut
    • 376
    currently running gemini on dm800s but was goin to flash new image,prob is i have motorised dish set up which a guy done for me,if i flash new image do i just enter my lontitude and attidude and start scanning,i dont want to mess this up and call the guy again, if i take a backup of my settings from dcc in etc/enigma 2/settings and flash new image then ftp thebacked up setting file will my motorised dish work ok , any advise wud be great,thanks, forgot to mention my dish is out of reach so i cant get near it if i must,cheers
  • southpaw
    • 2233
    There is an option to backup your settings within the image , no need to use dcc , ftp etc ,
    go to menu , software settings , and backup settings ,
    then when you install new image , you will be prompted to install backup ,
    failing that , there is a plugin from download section , called nfi backup ,
    btw , by default it wont backup your cccam settings
    • Wingnut
      • 376
      yeah mate downloaed that nfi backup and made a backup but i think its a backup of the complete image as the backup file is called gemini 4.70 nfi but i only want the settings,cheers
      • southpaw
        • 2233
        try the software backup in settings mate
        • Wingnut
          • 376
          iv had a look in at the softwaremanager and the options are
          manage extensions
          software update
          software restore
          backup system settings
          restore system settings
          install local extensions
          advanced options
          if i select backup system settings it backs up the complete image which i have saved to usb stick, if i go to advanced options i have
          advanced restore
          choose backup location
          choose backup files
          packed managemnet
          choose upgrade source
          i thinking maybe i need to go to choose backup files but which file should i backup, is it the settings file i back up then,i think it must be this, as u can see mate im not the smartest at this
          • southpaw
            • 2233
            i normally choose "backup system settings" , then prompts to restore when setting up new image , try it , if it doesnt work , you still be at where you are now (if you put gemini back on )
            • Wingnut
              • 376
              i backed up image from nfi tool and done a restore system settings on new image and gemini again
              • Wingnut
                • 376
                got it goin mate, flashed new image and just put in my long and att settings and dished worked a treat, thanks very much for trying to help me earlier, cant believe thats all i had to do ,cheers
