new dm800
  • yamar1
    • 970
    new dm800
    well, just got my new dm800 from t*ny at ya*otin, took 4 days delivery $230 usd all in around ?160. im well pleased with the box an unbelievable improvement from the dm500 iv been used to, just a couple of questions for you lot in the know as its my first enigma2 box.
    it has on it; boot76, gemi5.0, sim2.01, fan on the heat sink, tunner alps version l3,
    so is the gemini 5.0 image safe (will it brick the box with a bomb?)
    can i flash with dream up?
    and shall i change the image or stick with gemini 5.0, i liked the nabilosat darkstar 2 on the dm500, is there a nabilo image for the dm800 worth using which is stable.?
    Faster than Faster
  • Oily
    • Apr 2009
    • 123
    You can flash via the web interface.I'm using the DreamElite 1.3.3 image(Nabilo spin off) and its very stable.Nice skins with it to
    • southpaw
      • 2233
      some say newnigma is a good image , i am using dreamelite , and seems good , just make sure you put images cracked for sim 2.01 then you will avoid the "no CA error"
      gemini 5 is 1.6 based , if you wanna try various images , meoboot is good alternative to barry allen , just make sure you map your usb device 1st , and if 1.6 image is in flash , you can only put 1.6 in meoboot (original or cracked )
      Any issues and im sure Bubbles will sort you out , if he dont know , it aint wirth knowing
      • yamar1
        • 970
        iv just put dreamelite on it and meoboot is on the image, what is meoboot?
        Faster than Faster
        • westkill
          • 2378
          meoboot is like barryallen you can say boot other images from usb to try and keep dreamelite as main image in the flash and swap back to it
          • yamar1
            • 970
            ahh, so if i load an image to a usb stick and put it in the back of the db i can then run it via meoboot?
            im new to the 800 but i love it!
            Faster than Faster
            • westkill
              • 2378
              havnt done iit for a while i think you need to format the stick in the dm800
              then run the meoboot plugin to install the setup on the stick then you would have
              to ftp the image to /media/usb/meoboot/Mbootupload
              then follow install image then to boot new installed image i think
              • yamar1
                • 970
                thanks, il have a go.
                Faster than Faster
                • southpaw
                  • 2233
                  as above with meoboot , just make sure you map the drive in device manager , and ensure OE1.6 Images are in meoboot,(as dreamelite is OE1.6 )
                  Sugest you have a play with your image for few days to get a feel for it , Then maybe take a backup (plugin called nfi backup) , do some reading on meoboot , as install involves telnet and ftp`ing , Can all be done with dreambox control centre programme
                  • freck
                    • 1076
                    By all means have a go but be very careful on what image you use as your secondary boot image....you could end up bricking the DM,new sim and bootloader on that new unit so doesnt need much doing to it albeit the Gemini images are a bit bland.Be sure you use an image suitable for your particular bootloader and sim
                    As the other post says,have a play around with the image you have on first because multi boot isnt for the faint hearted unless you like tinkering around with it and not viewing with it.
                    Best of luck and I use Dream Elite Black Hole Image on mine and its a nicely put together image with all I need/plugins etc.
                    Freck
                    • westkill
                      • 2378
                      yea i would go with what these guys say first
                      especally using the right images and not crashing it
                      ive done it before and wished i had left it
                      • yamar1
                        • 970
                        thanks lads, on that advice i think il not bother with meoboot for now!. i succsessfuly flashed it with black hole and its much better than the gemini 5.0 which was on it so il stick with that.
                        one other thing, is there a way to dload the latest keys for digitv etc if its still going , i have a cs set up but anything else available?
                        Faster than Faster
