Dreambox 800 password
  • geo1561
    • Oct 2008
    • 8
    Can anyone advise please. Have just changed from a db500 to a db800.I bought this last year but have not used until I got to know how to use the db500. The 800 has CCcam 2.0.11 installed. I have connected db800 to my network and all is working fine. However when i try to use any dreambox tool and input the default user name and password ( root and dreambox)it fails to connect. Whats going on? Any help appreciated.
  • freck
    • 1076
    If your dreambox is online and you need to use a dreambox tool youll have to switch off "dhcp" and use your lan settings to connect to it.Set your ip address to 192.168.1.XXX on your pc and have your DB at one digit less than pc address and try again.
    Freck
    • geo1561
      • Oct 2008
      • 8
      Thanks for the reply but what I need is to be able to use DCC or Flash FXP amd these both need a user name and password.
      • davvo
        • Apr 2009
        • 666
        if you forgot the password
        and your image has no password reset
        you need to download via dm800 addons
        a plugin called Tuxcom
        which when installed becomes
        TuxBox Commander
        start TuxBox Commander
        scroll down to var
        OK
        scroll down to etc
        OK
        down to passwd and press 4 (edit) ( file name passwd not passwd- )
        OK on first line
        RED to clear line
        enter root::0:0:root:/root:/bin/sh with remote buttons like an writing an SMS
        OK
        EXIT
        save YES
        EXIT
        save YES
        EXIT
        EXIT
        EXIT
        then login with dcc or telnet ect
        login root
        no pass !
        • geo1561
          • Oct 2008
          • 8
          Brilliant did this today and all works fine. Thank you.
          • lcc300
            • 10
            In any Windows version:
            Step1: Click Start
            Step2: click RUN
            Step3: type: CMD
            Step4: type: telnet 192.168.1.2 <-- that was an exemple write the ip of your Dreambox instead of 192.168.1.2
            Step5: It asks for user type: root
            Step6: It asks for password type: dreambox
            Step7: type: passwd
            Step8: type your new password
            Step9: type your new password again
            Step10: reboot your DreamBox and you have a new root password!
            Second Way:
            If you don't have windows or Command Prompt then you can use PuttyTel.exe (download link: http://the.earth.li/~sgtatham/putty/...6/puttytel.exe).
            Then continue from step 4 above.
            when i try this it goes straight into bios (does not ask for user or password)!!!
            how can i get it to ask for my password so i can change it plz??
            • Curious123
              • 2591
              On your pc do Start > Run > CMD in the black screen type in telnet yourboxip (Return)
              passwd (Return)
              It should then prompt you to enter a new password.
              • lcc300
                • 10
                passwd (Return)
                as soon as i telnet myboxip (return) it takes me straight into bios. i cant type passwd (return). whats your thoughts? plz
                • fionn
                  • 28
                  Thanks Devo,
                  This worked.Hurrah!!!!!!!!
                  • hardy27
                    • Oct 2011
                    • 47
                    hello guys,
                    i have a bigger problem.... i have no password or username for my dm800 and root/dreambox was changed and the box has a pin so i cant acess setup or bluepanel on dm. i heard of puttytel but it does work for me can anyone help please?
                    thanks all
