hi all if you record a hd movie on the dream 800 can you transfare it to your pc and view it on a media player ???
cheers
cheers m8 do you know where they will be ???? what folder
.ts is the decoded MPEG stream that DM uses to record the files. You will need to either burn to DVD using a DVD burner but also ensure you have the codec files installed on your PC. What windows do you use?
Programs that open .TS files are:
MPEG-2 TS packet analyser Windows Media Player 12 Combined Community Codec Pack Squared 5 MPEG Streamclip Total video converter AVS Video Converter FormatFactory LEADTOOLS MPEG-2 Transport SDK Module
