DM800 pat / tuner errors
  • rbuffing
    • Jul 2010
    I just received my dm800 cloent but receive a lot of tuner errors.
    Does anyone have a fix for this?
    Thanks in advance
  • southpaw
    • 2233
    make sure your channels settings are up to date , also try a differant image , as i think gemini suffers from this issue , dreamelite doesnt (i read this so cant 100% vouch for it)
    • deffc0n
      • Aug 2009
      • 894
      What revision tuner ?
      channels FTA work ?
      • maaubry
        • Jul 2010
        • 16
        use Nabilo. Though not sure if they work on Clones. I know Gemini has issues.
        Also, check the tuner settings in the Sat Search section of menu. Might need to tweak the LNB settings.
        • samoloko
          • Jul 2010
          • 43
          does the tuner of 800 box get Improved compared to older models
          • maaubry
            • Jul 2010
            • 16
            yes. very much so. I have a 500 and 800 setup on the same sats and the 800 captures more channels. The 800 has a more sensitive tuner.
            • maaubry
              • Jul 2010
              • 16
              sorry one more thing, if you are downloading settings for sats from users or even from the image plugin, you may end up with transponders your own dishes can't get. So you will get errors. Just a note. sine depending on where you are, satellite signal strength and channels varry.
