DM800 wierdness etc.
  • d00k69
    • 26
    Hey guys, got a bit of a weird one here, Dm800 cl*ne with sim 2.01 , Bl76a and dreamelite 133D patched by Rami.
    Used dreamup to flash 133D image to box then used the enforcer tag to use the flash button again to upload secondstage 76a.nfi (without rebooting after image flash). DM boots up fine, do the wizard malarchy etc, all well and good.........until i reboot the box and I get the -> error! msg.
    Start DreamUp again and and i get the no CA screen, but I do get a IP address so I can flash via web browser. Any help appreciated.
    Cheers
  • southpaw
    • 2233
    76a is a patch for using original unmodded images , you are using it with a modded ramimaher image , either use one or other , (rami image without 76a or original unmodded DE1.3.3 with 76a )
    • d00k69
      • 26
      Thanks for the advice m8, i was doing it arse upwards I think. I solved the problem by flashing with 76a nfi in webif first then rebooting with front button pressed then flashing with an 76a DE image other than ramimaher's. Did the job.
