dm800 clone and external usb hdd
  • sukhvi
    • 42
    hi all,i have a dm800 clone which has no harddrive, i am running bl76 and sim 2.01 with orginal dreamelite 1.3.3 image,can i connect an external usb hdd to the dm800 usb port?. the external usb hdd i used to use it on a eurovox 7000 before.when i connect it to the dm800 it does not see it.do i need any plugins or any type of activation?thanks for any helpfull input
  • phils_confused
    • Mar 2009
    • 11
    Make sure the he'd is formatted to something Linux can see like ext3. I just googled 4 a formatting program to do that. Then just unplug the box. Plug in the hdd then power the box up. Go in to settings and a hdd option will b there. Initialise the drive and it should be good to go. If the drive is powered off the USB port it might not have enough juice to run the drive properly though.
    • rapscallion
      • 141
      What did you use. I cannot find anything aprt from I shoud use gparted.
      • phils_confused
        • Mar 2009
        • 11
        paragon hard disk manager
        • Nev1337
          • 57
          use acronis disk director suite its better for usb hdd?s
          • .: JaCkPoT :.
            Retired Sat TV Addict
            • 5607
            my dm800 doesnt even pick my ext hdd up
            ___________________
            In the good old days, I had
            DM800s HD
            Openbox S10
            TM500
            DM500s
            90cm FortecStar dish
            Maxx 110cm Dish
            Technomate 2300 Motors
            • rapscallion
              • 141
              I had the same problem.
              Sometimes the power is not enough of things like WD passport. I ended up using an old seagate 320 powered HDD. Even then I had to muck about with it for ages.I could see it in set up system then harddisk but not in device manager. Not too sure how I ended up getting it working but in the set up-system- harddisk I picked initialization. It failed but strangely enough and I have a feeling it may have been pure coincidence the device manager saw it then I formatted it mapped it and put the recorded path to it and it worked.
              • yamar1
                • 970
                get an internal one, much better and less clutter. iv put one in mine a samsung 400gb (?39 brand new,delivered ebay), initialised it in the settings and it was away, records mint.
                Faster than Faster
                • phils_confused
                  • Mar 2009
                  • 11
                  I second that. I had a powered usb drive and my box was so unstable with it it was unreal. I put an internal drive in and its perfect. Just make sure you have a decent cooler, or you're asking for trouble with overheating
